Now before you burst out laughing, try to be serious for a little bit and try to bear with me for a moment.
A little background:
Meditation has been around for a long time. It's a good technique for calming your mind and relaxing the body. You can let go of it all or channel intense focus on a single thing. I've played with meditation in my own meager little ways, and have found it to be quite impressive in many aspects.
How does this pertain to cars? Well, the same principles can be applied while driving. The biggest factors are calming of the body and the ability to intensly focus on any aspect of the car.
As for me personally, I've driven this Subaru Forester for nearly a year. Subaru has gone far out of its way to isolate the driver from the outside world. Senses of what the car is doing is almost non-existent: engine feel, drivetrain feel, road feel, traction feel, steering feel, pretty much everything. To the common person, this is a nice thing, making for a very comfortable ride. Unfortunately, it's a problem for someone pushing their car and wants to know what's going on.
I'll put this is some perspective. For the most part, I can get a new car or drive a car for a short period of time and get quite comfortable. My old Ranger I had before this car I only drove for say 3 months. By the time I sent it off to the junk yard, I could litterally drive(and drift) the snot out of it with a good amount of comfort and control. Going back to the Forester which I had for quite a bit longer, I still don't feel the same connection. The feedback isn't there, or should I say isn't pronounced enough, to allow the learning of the car's behavior. It's odd to explain, but basically, the car is hard to learn because of the isolation.
How to overcome this problem? Meditation.
Meditation:
Ok, it's not something new to me personally, but you guys might have some fun trying this. Basically, as you drive your car, try to meditate. Now the exact way to do this is person dependent. I think everyone has their own way.
I find a couple things work for me:
1) Breathing -
Try to breath in and out in a controlled manner. Control the speed and depth of the breath. Every in breath and exhale breath should be controlled, slow, and deliberate.
What you're trying to do is to free yourself from other, random thoughts by focusing on one task. It's to slow down and simplify what your mind is doing. At the same time, it focuses it on one, single task.
2) Focus Points -
Now, I've done this in the past with my body, basically as a relaxation technique before I sleep. However, it does way more than that. It focuses and aligns your thought and body together into one. What I do is to focus on one single aspect I can feel. For example, laying down, I have my arms at my sides, elbows bent 90 degrees with my hands pointing up and my fingers pressed together, like praying but palms appart, fingers seperated. There is some constant force applied between the tips of the fingers, thumb pressed against thumb, index finger against index finger, and so on. What it causes eventually is some small pain, some numbness at those points from the constant pressure. It creates a focus point to concentrate on. In time, you can feel the throbbing in tune with the pumping of the blood. You can focus on the heart and every pump that goes to your fingers. You can sense the delay between each beat and the small wave of pain in the fingers. You can feel the heart beat and a wave of fuild spreading throughout your body like a ripple in water from a fallen pebble.
This gets quite interesting with how much you can feel. You can advance it by going to two points, focusing on two parts at the same time rather than one. I tried both my hands and my feet. Being far appart, it makes it harder. With some practice and time, you can get your mind to the point where you can "see" both parts at once. Essentially, you have a whole instantaneous and realtime image of your entire body in your head. It's pretty cool really and the effects can be felt for several days after. You can still sense your whole body at the same time the next day even when just walking around. Everything's in tune. Everything's working together.
Again, how can this relate to the car? Change the points.
Instead, focus your meditation to parts of the car. Work on aspects like steering feel or suspension feel. Try to focus on a single tire. Get yourself to a calmed state and begin focusing on one of these aspects. Let's start with the steering and the feel. Focus on the steering wheel. As you drive, turn it ever so slightly back and forth. "Listen" for changes in the car. What senses can you precieve. Can you feel the tires as they flex? Can you feel the texture of the road? Perhaps the leaning of the car comes into focus. Turn the wheel back and forth slightly and feel the car rock gently back and forth. Change speed and magnitude of the steering. How does it feel different? Can you feel different suspension components come into play? Any additional resistance from the swaybar? Can you feel the tires leaning a little more or perhaps slipping just a hair? Try to focus on the front and rear at the same time. Rock side to side. How does the front and rear differ? Can you feel the weight shift around? Side to side, perhaps rotate a little front or back.
Try working the accelerator and brake. Speed up a little, slow down. Feel the car shift weight backward and forward. Feel the tires and how they grip. You can keep steering a little or stop. If you keep steering and accelerating and braking, you can begin to feel how the shifting weight affects how the tires feel. The higher load increases flex. Perhaps, you can feel a tire looser. Go back to the weight and the rocking of the car. Try to play with it. Roll it around. Side around to the front. Can you feel how it moves around you?
All of this is to try to achieve some specific goals. First, it calms you and focuses your mind. Second, it sensitizes you to the car. Finally, it brings your mind and your car closer to being one.
Anyways, feel free to comment. Try it out, see what you think. Practice with it. It gets easier the more you do it. I've tried this here and there in the past when driving but never stuck to it. I'm personally hoping to get a routine of this as I head home from work nightly to help me get better in touch with my car, something I've needed to do for a long time as it doesn't come so easily as other cars have. I just thought I'd share my ideas a little and hopefully help out a few people.
Meditation:
1) Breathing -
2) Focus Points -
