Make smoke from rear tires?
  • Make smoke from rear tires?
    i saw it in the drift vedio.
    how to make much smoke form rear tire, when just start?
    add some brake and floor it...If you do it alot you can get a good burnout
      can you tell me more little step for it???
      i need add hard brake or little brake on it first?
      because i did it today, but still can't did it.
        - are you trying to keep the car still, and just spin the tires?
        - or are you trying to get more smoke while you drift around a corner?
          i want "trying to keep the car still, and just spin the tires"
          i am drift beginner
            i am drift beginner
            line lock will be your answer
              you mean like a powerbrake?
              if your running a MT hold the clutch in rev it up like half a g before redline, pop the clutch out and when you feel tire spinnage.get on the brake.if you brake too soon you will either stall or it wont spin the tires... good luck!
                if you want to do it while drifting, you just gotta figure out how to spin the tires faster while sliding. i got a buncha pics of me doin it. you can do the left foot braking thing while drifting. but thats no fun.
                  just do heel toe with you brake down pretty ard and your gas reved to like 4500 or so, then put it in 1st and absolutly dump the cl;utch, if you go slow you will burn up your clutch. then floor it and either take off, hold the brake or push the clutch in when your done..
                  good luck!
                    yeah but aren't you beating the hell out of your brakes by holding them while your flooring it! Just get a line lock for the front brakes.
                      what is "line lock"??? i am drift begenner
                        it's an electric solenoid that you install in line with your front brakes, Then you hold down the brake and press the button tied into the device. when you let go of the brake the front brakes will stay locked as long as you hold the button. Then punch the gas and burn like all hell broke loose, let go of the button and you release the front brakes. look here for a good install article.
                        Line lock Install
                          Tashi, no offense but your question has nothing to do with "drift-beginners".
                          If you want to learn how to drift, "burning out" on a stand still will NOT teach anything about drifting.
                          Again, don't take it into offense, it's just that you keep saying that "i'm a drift beginner" and burning out will not make you better
                            1) learn how to drift
                            2) learn how to drift on non-crappy tires
                            3) learn how to drift with lots of throttle
                            4) make big full throttle drifts on non-crappy tires that leave big plumes of smoke
                              The amount of smoke also depends on what kind of tires your running.
