I'm may be wrong but isn't heel toe relatively similiar to double clutching
double-clutching can be used in conjunction with heel-and-toeing, but it isn't totally required. If you look at all the Best Motoring videos, none of the drivers there double-clutch, but they all heel-and-toe.
Here's how you do it:
heel and toe without double clutch
you're in fourth gear, you hit the brakes with the left side of your right foot. then, you put in the clutch, bring the gear lever to neutral, blip the gas with the right side of your right foot, put the gear lever in third, let out the clutch, and then continue braking.
heel and toe with double clutch
you're in fourth gear, you hit the brakes with the left side of your right foot. then, you put in the clutch, bring the gear lever to neutral, let out the clutch, blip the gas with the right side of your right foot, put in the clutch again, put the gear lever in third, let out the clutch, and then continue braking.
now, think about it from a technical point of view: if you leave the clutch in (ie. don't double clutch), then the input shaft in the gearbox will slow down or stop, while the output shaft stays spinning at road speeds. When you then put it into a lower gear, it uses the synchros to synchronize the speeds of the shafts so you don't grind the gears.
when you let out the clutch for your blip, you are using the engine to accelerate that shaft to synchronize it, and it takes all the stress off the synchros.
Also, you can double-clutch on upshifts. This is only really used for gearboxes that have problems (worn synchros, damaged dog rings, etc), or in big trucks. I had to resort to double-clutching on upshifts once during a race, because the reverse-lockout system in the gearbox failed, and it went into reverse instead of fifth gear. reverse desinigrated, and the metal bits chewed up all the synchros, so I had to double clutch on all upshifts and downshifts to be able to shift.
Go to howstuffworks.com and do some research on how gearboxes work. It's interesting, and it will allow you to make sense of what I have said.
oh, and for drifting, heel-and-toeing can be used, but it won't initiate a drift. I sometimes heel-and-toe, and then leave the clutch in just a little longer, to allow the revs to drop, but that just has the same effect as a clutch kick.
