Well, there's a certain slip angle (the angle of the tire's path to the car's true path, in a very simple nutshell) range through which the tire operates at its peak. (6-10 degrees for most race and high-performance street tires, usually) Below that range, the tire is being under-used and is not delivering full grip. Above that range, the tire is being over-used and is not delivering full grip. We consider over-use to be a fully sliding condition. In truth, the fastest way around a track is in a very subtle four-wheel slide around every corner to utilize the tires to their fullest. If the front tires are at a higher slip angle than the rear, then the car is understeering; if the rear tires are at a higher slip angle, then the car is oversteering.
Thus, drifting/excessive oversteer is not usually faster than grip except in instances when understeer is severe. (Very tight turns, mostly) I use initial oversteer to rotate my car and get it pointed the right way, and to overcome understeer.
Confuscious say: Tire sliding ever so much faster than tire gripping absolutely or sliding greatly.
You've just lost a lot of time.
