For Immediate Release
Hemel Hempstead, Buckinghamshire (United Kingdom) 15 August 2012
Team Falken UK has agreed a sponsorship deal with Mazworx, maker of the world’s most powerful SR20 engines. The agreement is to initially supply a custom specification engine for Alan Green’s S13 and is open ended to allow fellow Team Falken drivers Paul Cheshire and Matt Carter access to similar world beating equipment should the need arise.
Mazworx, based in Florida, USA, will manufacture and build the engine, based on a S13 block, although that is where the similarity from the stock engine ends. The block will undergo the Mazworx step decking process. Similar to a resurface, step decking involves machining a unique stepped profile into the block that ensures complete head to block gasket sealing under the most extreme pressures and temperatures. CP are custom making pistons to a Mazworx specification which will be retained by Carrillo conrods and run inside Darton sleeves. Rounding out the bottom end is a Mazworx billet crank, ACL race bearings and a Greddy high capacity sump.
Utilising a VVL head and Supertech valvetrain, the top end will be fully ported and flowed and is designed to run reliably at an incredible 10,000RPM. The valves themselves are operated by Kelford racing cams and Tomei adjustable cam gearing.
Forced induction will be provided by a Garret GTX3076 billet compressor turbocharger hooked up to a Mazworx manifold. Boost control is managed by a Tial wastegate, feeding a screamer pipe and downpipe also manufactured by Mazworx.
About Team Falken UK -- www.teamfalken.com
Team Falken UK is a drifting team based in the south of England, UK. Comprised of professional drivers Alan Green, Paul Cheshire and Matt Carter, the team compete in the British Drift Championship where Matt is the reigning champion. Alongside their BDC competition commitments, Team Falken UK also attends demos and other competitions across the UK and Europe for their primary sponsor Falken Tyre Europe.
About Mazworx -- www.mazworx.com / www.mazworxracingengines.com
Mazworx was founded in 2004 and has been on the cutting edge of performance, product research and development, and fabrication. The company has dedicated its expertise over the years from racing and product development to create the best performance parts on the market. Although known for the world’s most powerful Nissan SR20 powerplants, Mazworx performance product knowledge does not end there. From building full chassis race cars, CNC machine product development, full engine building capabilites, custom fabrication product development, they are your one stop go-fast facility.
