removing paint scratches
  • removing paint scratches
    hello,
    the other night one of my friend backed into the side of my moms car i was j/w if there was any stuff i could use to get his paint of my car. or will elbow grease and a cheesecloth do the trick. thanks and peace
    jooser
    I would try an industrial grinder. No man J/K. You can go to a parts store even Kmart and get some compound. What color is the car, Is there scratches or is there paint that needs to be removed. If your just removing paint you can use a soft abrasive compound and lightly rub it with a soft cloth. It might take some time but it will not disrupt the underlying paint. If you have scratches are they only in the clear coat. Is it a BC CC paint job or is it a solid color singlestage. If the scratches are only in the clear you can use some 1500 # grit wet/dry paper and some water. Lightly sand the scratch smooth but be carfull not to go threw the clear. Then buff with the previous compond. You can do the same as well if it is a singlestage as well.
