Originally posted by driftmunky
does Tein make anyting for MA70's?
These are all of the readily available coilovers for the mk3 supra. There are a number of very limited production kits from other companies you may be able to track down second-hand from japan, but by the time you rebuilt them you'd probably come out ahead to buy a new kit.
As for the LSD question -- all turbo mk3's have it, and the NA mk3's with the sport package have it. It is a fairly stout 1.5-way clutch type, but you will still want to change the fluid regularly. Also, adding that special "lsd additive" will make the lsd less aggressive, so don't automatically buy it because you think it'll make the lsd rock -- that stuff is designed to prevent the lsd from chattering when you're going 1mph in a parking lot with the steering wheel fully cranked.
And as for turbo vs na: A stock NA has enough power for drifting, but personally I couldn't see maintaining higher speed slides with it. And it is a hard engine to get more power out of. However the non-turbo engine has a very linear power delivery -- it makes 80% of its peak torque from like 1800rpm through 6000rpm. This means it is much easier to modulate the throttle.
A stock turbo car is probably worse for drifting than a non-turbo, but if you add full exhaust you'll get more power and better spool time. Unfortunately modulating the throttle with a turbo is more difficult and it will take a lot of practice to adjust your throttle without coming out of boost (and then having to wait for it to spool again). The stock turbo (ct-26) is quite large for it's day as a stock turbo -- only the Buick Grand National came with a larger turbo from the factory -- so it doesn't spool as nicely as other factory turbo'd cars...
