This is a few pics of probable the best drift prepared Ae86 going and that includes Japan . d
b
Owner and builder of this fantastic car is Darren McNamara,Ireland
Darren will be competing in the D1 GP at Silverstone on Oct 2nd and along with Eric O'Sullivan in His 20v Corolla
Car Spec
Engine:
SR20DET Conversion
Custom McNamara wiring loom
Greddy Puller Kit
3 Core McNamara custom "V" mount Intercooler with 3' piping
3 core McNamara custom "V" mount Radiator with custom Alu Header Tank
Custom Samco Silicone hose kit
Twin Pacet Competition Fans
HKS Tubular Manifold
Trust Turbo outlet
Blitz Nur Spec Exhaust System
Forge adj. actuator running 0.9 Bar Boost
Toda Racing 5kg flywheel
Custom McNamara engine mounts
Modified sump to clear steering rack
Lightweight altenator
Nismo Oil Cap
Stant Hi-Pressure Rad Cap
Sard Racing Iridium Race Plugs
Transmission:
Nissan 180sx Gearbox with modified casing to clear tunnel
Toda Racing Paddle clutch
Toda Racing Strengthened Pressure Plate
Custom McNamara Gearbox Mount
Nismo Solid Shifter
Custom McNamara Lightened and balanced one piece Prop shaft
Undisclosed rear axle
Locked Differential
Interior:
Fully Stripped out and lightened
OMP ARS bucket seat
FIA seat brackets
Williams 4 point 3' Harness
OMP Corsica steering wheel
Sparco Group N Snap off Boss
Defi Link Control Unit 2
Defi BF Boost Gauge
Defi BF Oil Pressure Gauge
Defi BF Water Temp. Gauge
Defi 0-9 Tachometer
Nismo GT Gear Knob
Custom McNamara Centre Console
Custom Aircraft switches
Varley Red Top Race Battery
Fibreglass Battery Box
Sprayed Audi A8 Silver
Exterior:
Vertex Body Kit
CBY Overfenders
Carbon Fibre Bonnet
Custom McNamara "Big" wheel wells
Kouki Redline Tailights
Kouki Headlights
Kouki Inner Fog Lights
Fibreglass Tailgate
TRD rear wing
Sprayed Imperial blue
Finished in McNamara Motrorsport Livery
Brakes:
Custom Brake Lines
Goodridge Hoses
Black Diamond Slotted Disks
Brand New AE86 Calipers all round
Project Mu MAX 900 Pads
Vertical Hydraulic Handbrake
Wheels & Tyres:
Compomotive ML's 15x8
ADVAN A048R 195/50/15 (Front)
KUMHO Ecesta 195/50/15 (Rear)
Fueling:
Custom McNamara SSB Alu Tank
Sytec FSE Fuel Pump
Sytec FSE Pre-Line Bullet Filter
Steel Braided Fuel Lines Running Through Car
Chassis + Setup:
Fully seal welded
Pop Riveted Chasis Rails
Custom McNamara 9 Point Roll Cage
T3 Four Link Kit
T3 Adj. Panhard Rod
Whiteline Traction Brackets
Largus D1 Spec rear Anti-Roll Bar
TRD rear ARB Poly Bush Kit
Powerflex Rear ARB Link Bush Kit
Whiteline Race Spec front Anti-Roll Bar
Powerflex Front ARB Link Bush Kit
T3 Roll Centre Adjusters
Quaife RHD Quick Rack
Ueo Style Adj. Track Control Arms
Ueo Style Inner over angle Tie Rods
Ueo Style Outer Tie Rods
TEIN Tension Rods
McNamara Front Coilover Suspension Conversion
Tokico HTS Shock Absorbers
McNamara Drift Spring Kit
TEIN Camber Suspension Tops
CUSCO OS Front Strut Bar
T3 Front Tri-Bar
CUSCO OS Rear Strut Bar
CUSCO OS Rear Tri-Bar
b Owner and builder of this fantastic car is Darren McNamara,Ireland
Car Spec
Engine:
SR20DET Conversion
Greddy Puller Kit
Trust Turbo outlet
Nismo Oil Cap
Transmission:
Nismo Solid Shifter
Locked Differential
Interior:
OMP ARS bucket seat
FIA seat brackets
Defi BF Boost Gauge
Defi 0-9 Tachometer
Nismo GT Gear Knob
Exterior:
Vertex Body Kit
CBY Overfenders
Carbon Fibre Bonnet
Kouki Headlights
Fibreglass Tailgate
TRD rear wing
Brakes:
Custom Brake Lines
Goodridge Hoses
Wheels & Tyres:
Fueling:
Sytec FSE Fuel Pump
Chassis + Setup:
Fully seal welded
T3 Four Link Kit
T3 Adj. Panhard Rod
TEIN Tension Rods
T3 Front Tri-Bar
