Uhhh yeah..... Should i get sway bars for my s13? I cant afford KYB's yet soooo.............. should i swoop em up?
Should i get sway bars?
Except that "helping" the setup is completely subjective. Stiffer sway bars at the rear typically lead to snap oversteer off the center of the corner or trailing oversteer at the corner exit.
While a set of properly matched (and that doesn't mean same diameter front to back) sway bars can improve cornering attitude, unless they are paired with good damping and spring rates all they'll do is sacrifice "wiggle room" for errors and make mistakes easier to make.
Sway bars are NOT a replacement for proper damping and spring rates.
Does the understeer happen under braking? At the apex? Exiting the corner?
If it's happening under braking or at the apex, then a larger sway bar at the front won't help, but a larger rear bar will encourage the rear to step out a bit more. It won't improve the front, just worsen the rear. It's a band-aid solution.
Understeer off of the corner, on the other hand, does require a combination bigger bar at the front and rear.
Why you ask? Because the bigger front bar will upset the car at the entry of the corner and off the center, so you'll want to loosen up the tail again.
This is why bar setup is a band-aid, you'll end up chasing your tail trying to correct for understeer and/or oversteer.
according to www.projectgirldrifter.com understeer is caused by
lack of skill so maybe all you need is practice.
Granted hes alex, so agreeing with him is a given but either way its your best bet.
Cut springs are a bad idea, the reulsts in your springs are rarely consistant when you do it, and can actually hurt your performance because of it.
Get the proper shocks/springs, if your just drifting for fun get some adjustable shocks and springs to your liking, if your a little more serious i say save up for a type of coilover set up instead.
As for the lack of skill remark, I gave it some thought, I have been doing an improper shift lock and heel toe so ur right! Lack of skill! Dizzam I suck!
