S13 Auto-manual issue
  • S13 Auto-manual issue
    Car 89 nissan 240sx Fastback/hatchback
    Conversion Auto-manual 95 pedals
    Motor Conversion SR20det Redtop S13
    No abs, no hicas Base model no sunroof but had O/D
    MAF S13 SOHC MAF
    Exhuast 5zigen Rocket
    manifold Stainless steel
    Intercooler Side-top mount
    Wiring for harness, srswap.com
    Auto-manual wiring dont have any idea???
    turbo elbow hks possibly
    gauges Equuiss
    boost gauge autometer
    Stock height
    stock SR
    Problems, No ignition signal from auto-manual what needs to be bypassed for this?
    i could possibly have wrong ECU with a E6
    what wireing needs to be changed or bypassed for this swap
    unless i need to get a nuetral safety for a SR?
      At the fuse box next to the battery, there is a two wire plug (probably the bottom one), connect those two wires together.
      someone correct me if I am wrong.
        What type of ECU you got?
          feel underneath passenger side fuse box next to battery. There's a plug with two wires. One is grey, the other black. Cut them back far enough so you can connect them. Done.
