HERES THE LOW DOWN ON MITSU STARIONS .
first just to strat things off the right way and to clear the confusion, i was knowed to be a mitsu specialist and served as a tech consultant on several starion projects and magazines, ive built several engines rating 500hp to 700hp, my other specialty is the sr20det i like building 4 cylinder engines that can spank the big boys
weather drag,auto cross or street the starion is a very good strong platform to start on, the car is desing for touring sport independant suspenssion, 410 final gear w/ lsd, 2.6 ltr engine inline 4(one of the biggest 4cyl engine, td05 turbo frontmount intercool, hp rating is 185 hp@ stock 10 psi, this car is advance in its class, originaly this engine came from a truck just like the ka24, you will notice that these engines can produce alot of thorqe, on the starion block, the block is basicaly bullet proof it is very strong and can withstand upto 400 hp stock, the only draw back i found was the stock cylinder head tends to crack because of the jet valve mitsubishi implemented, that problem is old and cured, you can pick up a head for about $350 to $450 w/no jet valves, now as far as drifting i havnt yet to see a starion drift yet, how ever ive tried it and it is very well possible, all you need is to get the beast on a diet, fiber glass fender, hood etc, as some people dont know there is a steering udjustment underneath the cross member that can be adjusted to shorten the turning ratio or to get more angle for a wider drift, ok going back to the main subject, before any thing i sugest to steam clean the engine, and have it running right at stock form first, then do your upgrades after. it is more simple to trouble shoot when somthing goes wrong. there are more informantion and special mods that can be done to the starion, however it is to much to list on the board.
compliments from
C2 POWERHAUS
PAUL
weather drag,auto cross or street the starion is a very good strong platform to start on, the car is desing for touring sport independant suspenssion, 410 final gear w/ lsd, 2.6 ltr engine inline 4(one of the biggest 4cyl engine, td05 turbo frontmount intercool, hp rating is 185 hp@ stock 10 psi, this car is advance in its class, originaly this engine came from a truck just like the ka24, you will notice that these engines can produce alot of thorqe, on the starion block, the block is basicaly bullet proof it is very strong and can withstand upto 400 hp stock, the only draw back i found was the stock cylinder head tends to crack because of the jet valve mitsubishi implemented, that problem is old and cured, you can pick up a head for about $350 to $450 w/no jet valves, now as far as drifting i havnt yet to see a starion drift yet, how ever ive tried it and it is very well possible, all you need is to get the beast on a diet, fiber glass fender, hood etc, as some people dont know there is a steering udjustment underneath the cross member that can be adjusted to shorten the turning ratio or to get more angle for a wider drift, ok going back to the main subject, before any thing i sugest to steam clean the engine, and have it running right at stock form first, then do your upgrades after. it is more simple to trouble shoot when somthing goes wrong. there are more informantion and special mods that can be done to the starion, however it is to much to list on the board.compliments from
C2 POWERHAUS
PAUL
