Originally posted by Whisky
I'm quite familiar with the Subaru WRC rear wing and the purpose of the strakes, but that also comes at a loss of efficiency.
...speeds are greater in WRC then they ever will be in drifting.
Airflow separation is largely dependent on the car
interesting case in point: For the longest time, I would drive my AW11 MR2 with the rear decklid open, just to let out a little more heat from the engine bay. It helped a little bit, and the lid always stayed down. That car had a few problems, so we got another one (we're not big spenders... cheaper to replace than repair!). The next one had a sunroof. Shortly after, I am driving down the highway, and I decide to pop the decklid to let the engine run a little cooler... all is good. Then I decide I should give myself the same treatment, and open the sun roof. all is good... then I notice that the decklid seems to be floating up about 45 degrees from horizontal.
I figure that the airflow with the sunroof down came down and attached to the back of the car just before the decklid, thus pushing it down. However, when I put the sunroof up, it was just enough to engulf the decklid with turbulence and lift it up. It seemed that the air just attached later, and a particular swirl of turbulence just picked it up.
Therefore I would deduce that even on that car, with no fastback, a wing mounted even 4" off the trunk would be effective. Perhaps it wouldn't be as effective as if it was roof height, but still, it would work reasonably well.
...focused on a Formula SAE project working to develop low-speed aero downforce. If I recall correctly they had some success, but the car was ugly as can be.
We should keep this going MalcoLm, see if we can come to any interesting conclusions...
I would be more impressed by body kits if they were also functional in directing air to cooling ducts for the radiator, intercooler, oil cooler, etc.
