nismo lsd ?
  • nismo lsd ?
    well its time for me to get a lsd for my 93 240sx and was wondering if any of u guys have any info like pros or cons on the nismo lsd? any usefull info would be appericated.
    heres the link to it.
    http://www.optionimports.com/ni2waylsd892.html
    well i havent really tryed any lsds yet but this is wat ive heard...still doing some research...
    this is what www.phase2motortrend.com
    had to say about it
    Nismo 2-Way "Street" LSD 1989-98 240SX *NEW ARRIVAL!*
    Nismo clutch type "street" limited slip differential kit for all 1989-98 240SX equipped with OE open diff or VLSD from the factory. Nismo LSD drops right into diff pumpkin with no modifications, uses existing output shafts, LSD is set at 70 lb-ft breakaway torque from Nismo, comes with diff fluid, new bearings, diff cover gasket, and output flange seals. Everything you need to install the LSD into your 240SX! Please change the diff fluid after break in.
    Each side of the diff comes with:
    # 2 friction plates
    # 2 friction discs
    # 1 spring disc
    # 1 spring plate
    Some people found this Nismo units to be fairly quiet, and doesn't make much noise as compared to the Kaaz Unit. However for persistent race use and drifting, the KAAZ unit is a superior unit over Nismo.
      thanks alot for the info sr drifter. appericate it.
