RSR springs, stock shocks?
  • RSR springs, stock shocks?
    is this ok, i don't have a lotta money, and i need something stiffer, would cut be better? i could give a crap about the ride quality. anyone know about tems, i hate it, and i want it to go away, can i easily, thanks
    bump
      cutting your springs can make the spring rates softer when you heat it up, so that wouldnt be a good idea if you need a stiffer setup. i think rsr springs are the stiffest of the aftermarket springs.
      just get those then when you save up more money get some struts to replace what will be your blown ones
      get kyb agx's or something of that matter.
        Spend the money you wanted to spend on springs on a katana and commit seppuku.
        If you buy aftermarket lowering springs, you MUST buy shocks that match or else you are committing a crime of modification.
          ehh, whatever, i'll just save and buy some used teins from my friend
