Quick question. Stock LSD on my 240 does it need to be changed? in a drift it seems only one wheel spins?
s13 must do's
You might have a factory VLSD. The viscous coupling uses a fluid that resists shear loads, so as the plate connected to one axle spins faster than the other, the fluid between them causes the other to spin also, thus transferring some torque to the wheel with more grip.
Not all VLSDs work as well as some others, even from the same manufacturing batch. Part of this is because they are very sensitive to manufacturing tolerances because they rely on a fluid to resist shear, so small differences in casting and such can have a large impact. Even the Renault F1 team had trouble getting consistent results with them when they were running a front torque transfer system in the late 90s.
Even the best-functioning Viscous LSD is going to underperform compared to a clutch-type like the nismo, kaaz, cusco, etc. This is particularly true for drifting. I would suggest saving the cash for a good clutch-type LSD. I have a kaaz 2-way and it was the best money I've ever spent on a car, no doubt.
OK, The car will not do donuts, only one will spins. When the rear is lifted and one wheel is spun, the other spins counter. When one wheel is off the ground ( dont try this at home) and you put it in drive, one, the wheel in the air will spin. car will also do burnouts with both tires spining. what kind of diferential is this?
92 240sx automatic
you prolly have open diff....so get the part that says without OE LSD......
Well, you only have to buy it once.Originally posted by tuwinu_duriftu
do you really need to buy one everytime you drift?
No, you don't absolutely need it. But drift an open-diff car and then drift a car with a quality LSD and you'll see that life is much better with an LSD. If you aren't serious about drifitng then a serious LSD may not be for you, but even if you plan to road race, the LSD will again prove beneficial.
