If you installed a OBII Adapter on your S13 240 would it then be possible to install a KA Turbo on a KA24DE Engine? Haven't seen this answered anywhere.
ODBI To ODBII on S13
i already investedgated doing this. there are many more sensors on the obd2 that is not just wiring, sensors and sendors and stuff.
also, doing this and getting the greddy kit will not yeild a legal turbo 240, the greddy kits are still illegal.
Legality isn't really what I'm worried about here, but is it physically possible to do? The only sensor I see that might give a problem is the Oxygen sensor near the catalytic converter, but couldn't there be a way to disable this sensor within the scanner itself? Could any computer based scanner(handheld or PC) possibly do this?Originally posted by sdtougei already investedgated doing this. there are many more sensors on the obd2 that is not just wiring, sensors and sendors and stuff.
i found some guy that did obd2 to obd1 conversions for the s14, i wa emailing back and forth with him for a while and they are more sensors, i dont know haw many, its also the cams (less duration for lees emitions) and ecu.
why do you want to do this?
Shops are alot harder to find around here that would do a complete swap(and do a quality job) or else I would get a SR20 or CA18. I can do a turbo myself but don't have the time, equipment or experiance of a full motor swap. So this is basically the only route I have without purchasing a whole new car.Originally posted by sdtougei found some guy that did obd2 to obd1 conversions for the s14, i wa emailing back and forth with him for a while and they are more sensors, i dont know haw many, its also the cams (less duration for lees emitions) and ecu.
For my money you can't beat the NSport kit. Its an extremely complete kit, its very well proven, and it makes damn good power.
The Stage I kit makes about 240hp to the wheels at only 7psi. I have personal experience with several cars equipped with this kit and I can tell you it works perfectly, and they run extremely smoothly and reliably.
Check em out www.NSport.com
