http://www.tekniqauto.com
Today well be looking at how to install the Tekniq Auto Steering Wheel and Snap Off System. Kaz at Tekniq Auto was nice enough to provide me with this kit.
It should not only provide a great new look for the car's interior, but also serve as a great theft deterrence system since each pattern is unique, and make it easier to get in and out of the car with the roll cage bars being in the way of my legs.
Today's Lab Rat will be none other than this sexy beast you see right here
Here we see the kit components: Suede Steering Wheel, Hub Adapter, Hardware, Horn Button, and Snap Off System
**Before you begin make sure to disconnect your battery ESPECIALLY if you have airbags**
Say good bye to the JDM S15 Steering Wheel(which btw is now for sale in the classifeds section)
First, locate the covers on each side of the factory steering wheel and pop them off with a screwdriver...
There should a 10mm bolt on each side, in some cases you will have a special tamper proof bolt which you need a factory key for.
Remove each of these bolts to losen the airbag.
The airbag should slide right out...do not pull too far or you will break the wire harness!!! Pull it off to the side and bust out your breaker bar and sockets!
There should be a large nut directly behind the airbag unit. In this case it is a 19mm.
Remove the nut and do not lose this as you will be reusing it to mount the hub adapter for the new wheel.
Now heres the tough part. Gather up all your strength.....yes all of it and pull the steering wheel off. This is not as easy as it looks, i had to pull with my whole body weight and wiggle it at the same time. Make sure not to smack yourself in the face.
Here we can see the difference both in size and weight. The Tekniq wheel is slightly smaller and being suede, will provie a nice grip pad and quicker steering response.
This is what it should look like once you have removed the stock wheel...
Line up the new hub making sure that it is centered so that the wheels are straight.(After completing the install you may have to move it around again to get it right after driving the car and realizing that its slightly off center) Once it is sitting on the spline....hit it a few times lightly with a rubber mallet to ensure that it is sitting properly at the base of the shaft.
Now reuse the 19mm nut to tighten down the hub onto the steering shaft. Torque to the appropriate specs. The black wire you see is for the horn and will connect to the snap off adapter later on.
Install the rubber hub cover....
Install the adapter for the snap off system using the supplied bolts and an allen key..again make sure everything is centered and that you have connected the horn wires properly.
This completes the first half of the install....this is what you should have so far...
