Does anybody know which wire is the Speed Sensor to the ECU on the Harness where it plugs into the ECU in the kick panel on the '96 240SX SE
? Any help provided would be greatly appreciated. If you know, you can contact me at topgun_2012@yahoo.com. Thanks.
Problem Solved. Same Wiring pattern from '91 ECU. Yellow(w/ green stripe) wire 8th in from the top( as mounted ) in the center row. Haven't really pushed my '96 to the limit yet, just pushed it enough to know the speed sensor is clueless. ( Went just off Speedo, somewhere around 122~125, Speed normally cuts off at ~118 )
? Any help provided would be greatly appreciated. If you know, you can contact me at topgun_2012@yahoo.com. Thanks.Problem Solved. Same Wiring pattern from '91 ECU. Yellow(w/ green stripe) wire 8th in from the top( as mounted ) in the center row. Haven't really pushed my '96 to the limit yet, just pushed it enough to know the speed sensor is clueless. ( Went just off Speedo, somewhere around 122~125, Speed normally cuts off at ~118 )
