240sx What to do next
  • 240sx What to do next
    To make a long story short. I need alot of undercar front end parts for my 240 making love to a curb. its a 80k 2.4L automatic. This A drift car only and is not a daily driver by anymeans.
    Damage assement is:
    Core Support pull $80
    Headlamp brackets $30
    Lower control arms ?
    Other Suspension damage?
    Tension rod bracets/power brace $150
    Oil pan $50
    Oil pickup?
    Unforseen?
    Belive it or not, Tein tie rods bent my frame! and are not damaged at all. not sure if i should be happy or sad
    My options are Fixing what i got? Sr20det Front clip and convert to manual?
    Sr20Det Cost
    Front Clip $2300
    Brackets for headlights $30
    Intercooler?
    Drive Shaft?
    Pedels and cylinders included?
    Transmounts $200
    Core Pull $80
    Individual and gradual upgrade
    Sr20det $1300
    ECU Included
    MAF $60
    Harness $200
    Powerbrace $150
    Mounts $200
    Core pull $80
    Pedels & cylinders $200
    Drive shaft included
    Light brackets $30
    Intercooler ?
    Suspension ?
    What would you do, and if you could fill in the blanks on my costs let me know, thanks
    3
    Fix what i got
    33.33%
    1
    Swap Sr20 w/ Front Clip
    33.33%
    1
    Swap Sr20 Individual Parts
    33.33%
    1
    The poll is expired.
    well i know that you can buy a used 5 speed conversion that will include everything but the actual transmission for under 200 dollars. a stock side mount intercooler off of an s13 is around 50-100 dollars. if you dont have intercooler piping thats about another 200. cheaper to do a front clip in the long run. i am in the ending stages now of an sr swap and i just bought the motor/tranny/ecu etc. should ahve gone with tht e clip. so i guess bottom line, my opinion: do a front clip. cheaper, and easier.
