4 lug to 5 lug s14
  • 4 lug to 5 lug s14
    are the oem 5lug hubs interchangable with the 4 lug hubs on an s14?
    just curious if i can go to the dealership and order the hubs and bearings from an SE and install them onto an LE
    thanks
    yes yes yes. (I said it 3 times b/c the message was too short.lol)
      how about the S13? can i just replace hubs from the 5 lug S14 into my 92 S13?
        only in the rear it will work. as for the front if you want to run s14 5 lug hubs you will need s14 lower control arms, s14 knuckles, and s14 brakes. good luck or you can just get I would recommend peak performance 5 lug for the front cause they come with extended wheel studs and they manufacture everything in the good old u.s.a
        good luck
          good luck
          Speaking of the front hubs, can anyone find the best price on the 5-lug hubs, including peak performance, gto/attain, and any others you can suggest? Also peak performance has these "street" hubs coming out in May, I don't know how well these would stand up to some abuse:
          http://www.store.yahoo.com/phase2mot...est5lughu.html
          Also here are some good articles on the swap:
          http://www.tougefriends.com/media/ht...ame=News&sid=9
          http://www.sportcompactcarweb.com/pr...cc_projsilvia/
            good luck
            yeah if you wann pay like $550 http://www.optionimports.com/pepe5lughubp.html , this is the best price I've found for the attain hubs,
            $385 http://www.optionimports.com/at5hohubki18.html
              i have found that the s14 front 5lug is a direct bolt on onto the s13 if you use these 5lugsleeves.com.
              this might be cheaper
                wow didn't know abou those sleeves. thats a smart move on that guy. Only if i knew I wouldn't have drilled my coilovers out oh well too late now.haha Yeah the peak ones are exspensive but you get what you pay for. Plus the peak ones like I said come with extended wheel studs.
                  my 1 88 u, thanks for the link! I really needed it!
