Noise help
  • Noise help
    Hey guys in my 240... i got a little noise.. and i dont know what it is... i dont like those.
    It only happens during hard cornering and only when im turning to the right.
    Its kind of a knocking noise... like if youve ever heard CV joints bad in a FF car.
    Any idea on what this is?
    97 240sx Se
    oh and the noise is defintely comin from the rear end
      I think its the axels.
      I think the boot on your half-shaft is going. You will need to replace your axel. By the way, how many miles do you have on your car. Also, if you have an LSD, whens the last time you've changed the Diff oil.
        I think that one of the bushings in your sway bar is worn out, or if ur running an open differential, you most likely destroyed it....what kind of noise is it, like a knocking or a raddling?
          its deff. knocking. Almost like cv joints knocking
            it only gets loud through corners? id say it was a boot on your rear end
