Carb Tuning
  • Carb Tuning
    How do I Tune my 4-AC's Carb? Like the A\F ratio and all that jazz? anyone wanna give me a hint?
    Yikes....
    Do some reasearch online.
    I found out every thing about my weber/holley online,
    but just to start with find out the normal idle adjustment technique in something like a haynes manual. Once you have it set "normally", you'll probably learn which way to go with what.
    It's tough to do carbs man, keep at it.
    laters.
      Re: Carb Tuning
      It has a limiter cap on it. You won't be able to tune the Air/Fuel ratio effectively until you remove it. After that, turn the screw to the right to make the A/F ratio richer. Turn it to the left to make it more lean.
