Brake controller installation?
  • Brake controller installation?
    Hey,
    I'm redoing the brake lines on my 91 S10 Blazer that will eventually be setup for drifting. I want to install a bias controller inside the cab while I'm at it. What is the easiest way to install the controller? Should I route the entire line through the cab or should I just drill a couple holes and place grommets around the line and run the lines up to the controller and then back down to the frame? Any help would be greatly appreciated. Thanks
