Someone help to figure out, what happent to
  • Someone help to figure out, what happent to
    I have an LSD, (KAAZ)
    The problem is, can't find the right words, when i drive my supra forward, with speed about 20-40 miles/h i have to turn drivewheel slightly to the left, cause car try turn to the right... When i lift up rear and let the wheels spin with no contact to the ground, i see that left wheel spins a little faster the right.
    Someone can tell wtf happened?
    http://ff01.photofile.ru/photo/025/0...cfd5d70ba8.jpg
    http://ff01.photofile.ru/photo/025/0...cfc7424510.jpg
    Hi,
    Does the car pull to one side while accelerating? Does the car try to go straight during decelaration?
    If you answered yes to either question, it can be from two different causes.
    First problem could be the tires. Some defective tire that is wearing out funny can cause this symptom.
    Next possible cause can be a stuck pressure ring. This is caused mainly due to lack of break-in or improper break-in procedure. If your unit is a two way unit, you can disassemble the unit once and swap the pressure ring from right to left and left one to the right. Reassemble the unit and do some figure eight as if you are break-in the unit. This procedure should normally cure the problem you have.
    If you have any further question, please give us a call at 1-888-522-KAAZ(5229).
    Regards,
    Staff / Kaaz USA
