My J30 LSD seems to not work anymore..ideas?
  • My J30 LSD seems to not work anymore..ideas?
    Well, I bought a '95 J30 LSD in the fall and it had ~80k miles on it I believe. When I turned it by hand, both outputs turned together and all was well.
    I installed regular 80w-90 fluid (I think) nothing special, just the regular cheap stuff as recommended by a friend. I think it worked ok for a few weeks, but lately, it just acts like it's an open diff. WHen I put one wheel on ice, and the other on blacktop, I still spin a lot and move real slow, like it's not really engaging.
    Any thoughts on why it might be? Worn out? Wrong or bad fluid?
    Thanks,
    Nick
    my brother got a 240sx vlsd for his 96 240 about a month ago and its still working fine. i think u should do a overhaul (is that how its spelled?). try that and see what happens.
      The viscous fluid in the vlsd breaks down after a while and it just ends up not working, especially when it gets pushed hard a lot. this might be what you are experiencing.
        I guess that COULD be my problem, but the fluid has only been in there for probably 4 months and probably was only driven 2000 miles....and it's an automatic stock ka24de at this point..heh. Couldn't have seen much use, but then again it was cheap fluid.
        I might still try the heavier weight fluid soon when I swap in my RB20.
        Thanks.
        Nick
          Give it a quick tune up. That should fix the problem.
