Timing on an SR20DET
  • Timing on an SR20DET
    HEy everyone, could anyone give me a heads up on how to check the timing on an SR20DET redtop. I think my timing on my engine is off. Can anyone help me? THANKS
    get a timing light and conect a spark pluge wire from the coilpack to the spark plug(piston number one) and them time it from there, or go to a nissan dealership and have them do it for 80 dollars and hour.
      Thanks, but if there is something wrong with the timing, is it easy to correct it? How would i be able to do so? ANYONE?
        set the car at top dead center TDC (1st piston up and yellow mark on crank)
        Pull the valve cover
        pull cam angle sensor
        line up 1st dot on cam sensor shaft
        slide in so that the 2nd dot rotates and lines up with the mark on the cam shaft housing
        heavythrottle.com has a sr faq for pics and instructions
