nothing happens when i turn my key
  • nothing happens when i turn my key
    my car.....1995 240sx se motor ka24de
    problem...shut off as leaving gas station....no prior problems
    what works still.....headlights turn on dome lights work little things like that work
    dont??? well it dont turn over or try to...when you turn the key to the on position non of the dash lights come on as they normally would.....power windows mirrors....sunroof none of that works anybody have any ideas?????
    So all the lights work but none of the gauge backlights and it doesn't turn over?
    Maybe the ignition switch/key mechanism just went bad? Im not a mechanic Im just throwing out educated guesses.
    Im sure someone will pop up with a better answer. Good luck man
      u have head lights not dash lights or anything.. hmm check your fuses.. if not then is your car lowered?? if its real low did u move the harness in the fender well.. if not then check that.. tire might of eaten through the wires..
