rearend Swap questions.
  • rearend Swap questions.
    I have a 1985 corolla gts and I am looking to get another rearend because mine went out. Im wondering is there an alternative rearend from other cars that will bolt on directly on there?
    thanks
    1979-81 toyota supra bigger diff stronger, and has some pretty good disc brakes
      cool so its direct bolt on? or do i have to do minor mods? and also do you know if it has an lsd?
        Here's a Toyota supra online repair manuel for that specific year.
        http://www.cygnusx1.net/Supra/Library/TSRM/MK2/
        LSD equiped
          sorry emission but the MK2 has Irs that would need to be custom fitted to the corrolla and it doesnt bolt up
          the MK1 has a solid axel that has all the same attacment points as a AE86 so it bolts up but finding one with an LSD is harder but you could get the center section of a MK2 with LSD and swap it into the MK1 solid axel
            Oh cool. now i gotta hunt down an MK1 rearend and a MK2 middle lsd section thanks alot guys helped me out alot. so the MK2 lsd section should directly bolt on to the MK1 right? cool thanks again
