tightening e-brake on an fd??
  • tightening e-brake on an fd??
    when i pull my e-brake i have to yank on it all the way untill it will begin to stop, even when i pull it to that point it barely brakes. I have tried adujusting it under the actual boot in the center console but all that does is shorten the distance you have to pull it. I have also jacked the car up and found a set of nuts that can be spun and i thought that they would do the job but they were just loose and wouldnt tighten at all so i gave up on that. So then i took it to a mechanic who told me that he didnt have an awnser to my problem. The only thing i havent tried is engaging the e-brake then trying to tighten the nuts on the cable down by the caliper. Does anyone have any input?? p.s. i have new calipers and pads on the rear, and i own a 93 FD.
    Hello ,maybe the actual cable is stretched,this is commom if you yank on it alot.
