Ca18det turbo to SR20det
  • Ca18det turbo to SR20det
    Yeah dumb question, well dumb mistake....I bought a turbo (t25)which i thought was for a sr20det(t25g) motor but i just found out that there's 2 types of t25s. I just need it to test to see if my car needed a new turbo. Would it work? The ca18det turbo into a sr20det motor? I'm mad but it's my mistake. Help please?
    seeing that people put SR turbos on CAs all the time I don't see why not... it probably wont work as well but it will work none the less.
      Hello it should bolt up ,you may or may not need to re -clock it.
        What did you mean by re-clock it? Thanks
          any one else?
            Hello to "clock it" in terms of a turbo means to rotate the compressor side ,so that the outlet faces where you need it too
