240SX 5-SPEED Swap (DVD)
  • 240SX 5-SPEED Swap (DVD)
    http://store.driftingshop.com/245spswd.html
    240SX 5 Speed Swap Guide
    Covers all the basics and even goes further, with the 5 speed brake booster install, plus more!
    Covers the s13 & s14 chassis - as well as pulling the motor/tranny as one and then just pulling the tranny from under the car. So you will see it done both ways.
    Completely explain the wiring on the s13 & s14 as well as a “how to” on soldering wire.
    This video covers it all including motor/tranny maintenance – bolt/nut sizes and part #s – upgrades - oil seals – gaskets – new parts – tricks and tips etc…
    It also shows what is compatible between the s13-s14 and auto-5 speed.
    It goes in-depth to show how and why the parts work and will not work.
    This DVD is 2-1/2+HOURS LONG. – Using the newest DVD technology - Double Layer DVDs 8.5gb.
    5 Speed Swap DVD Chapter Layout
    CH 1 - Start
    CH 2 – Getting everything ready to pull the motor
    CH 3 – Draining & removing the radiator
    CH 4 – Removing the exhaust manifold
    CH 5 – Draining & removing power steering
    CH 6 – Removing throttle & cruise control cables
    CH 7 – Disconnecting wiring harness
    CH 8 – Auto tranny removal in & out of car
    CH 9 – Auto tranny shifter linkage removal under car
    CH 10 – Auto tranny shifter linkage removal out of car
    CH 11 – Auto tranny speed sensor & O2 sensor removal
    CH 12 – Removing the driveshaft under the car
    CH 13 – Removing the driveshaft out of the car
    CH 14 – Removing the interior stuff
    CH 15 – Auto tranny coolant lines removal under car
    CH 16 – Auto tranny coolant lines removal out of car
    CH 17 - Auto tranny mount & cross member removal under car
    CH 18 – Auto tranny mount & cross member removal out of car
    CH 19 – Auto tranny gusset removal under car
    CH 20 – Auto tranny crank angle sensor removal out of car
    CH 21 – Auto tranny bell housing bolts removal under car
    CH 22 – Auto trany bell housing bolts removal out of the car
    CH 23 – Auto tranny removal out of the car
    CH 24 – Auto tranny removal under the car
    CH 25 – Auto tranny flywheel & torque converter removal
    CH 26 – A/C compressor removal
    CH 27 – Bolting up the engine lift in the correct spots
    CH 28 – Pull motor/tranny clip
    CH 29 – Motor maintenance
    CH 30 – Clutch & flywheel install
    CH 31- Pedals and brake booster install and removal
    CH 32 – s13 clutch pedal in a s14 and vise versa
    CH 33 – Auto brake booster removal
    CH 34 – Front seat removal
    CH 35 – Under Dash
    CH 36 – Auto brake pedal removal
    CH 37 – Auto brake booster removal
    CH 38 – Auto brake pedal pin removal
    CH 39 – Auto brake pedal removal cont.
    CH 40 – Clutch master cylinder install
    CH 41 – Brake & clutch pedal installs out of the car
    CH 42 – 5 speed brake booster install
    CH 43 – Pedal installs under dash
    CH 44 – Clutch master cylinder
    CH 45 – Clutch slave cylinder
    CH 46 – 5 speed swap wiring
    CH 47 – Under dash wiring
    CH 48 – Under dash wiring out of car
    CH 49 – Wiring the pedals I the car
    CH 50 – Engine bay wiring behind fuse box
    CH 51 – Removing the ECU
    CH 52 – ECU wiring
    CH 53 – 5th & neutral pos. switches wiring
    CH 54 – ECU talk
    CH 55 – 5th & neutral pos. switches out of car
    CH 56 – Installing ECU
    CH 57 – s13 5 speed swap wiring convertibles too
    CH 58 – 5 speed transmission overview
    CH 59 – 5 speed tranny shift linkage woes
    CH 60 – Prepping the tranny
    CH 61 – Throw out bearing
    CH 62 – Tranny prepping cont.
    CH 63 – 5 speed & auto speed sensor differences
    CH 64 – Installing motor/tranny back into car
    CH 65 – Installing motor/tranny into car clip
    CH 66 – s13 & s14 tranny cross member differences
    CH 67 – s14 AT & MT driveshaft differences
    CH 68 – s13 & s14 5 speed driveshaft differences
    CH 69 – Installing driveshaft & tranny cross member
    CH 70 – Installing radiator fan & shroud
    CH 71 – Installing tranny in & out of car
    CH 72 – Installing tranny from under the car
    CH 73 – Bell housing bolt sizes & part #s
    CH 74 – s13 & s14 AT & MT gusset differences
    CH 75 – Starter motor & crank angle sensor install
    CH 76 – Installing short shifter & tranny fliud
    CH 77 - Tranny fluid
    CH 78 – Install everything left off
    CH 79 – Power steering fluid refilling procedure
