Rb25det 240sx swap dvd
This is a sticky topic.
  • Rb25det 240sx swap dvd
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB_DVD.jpg" width="350" height="303">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_26.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_30.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_19.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_47.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_25.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_24.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_23.jpg" width="350" height="196">
    RB25DET Swap
    <img border="0" src="http://driftingshop.com/RB25DET_RB25_SWAP_22.jpg" width="350" height="196">
    <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/IeXPXgEOpTE"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/IeXPXgEOpTE" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
    <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/d-wQN3-kW_8"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/d-wQN3-kW_8" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
    RB25DET SWAP / INSTALL - 240SX DVD
    <p><b><font face="Verdana" size="1" color="#0000FF">Chapter Outline<br>
    <br>
    1<br>
    Remove lower engine bay components<br>
    -TC Rods<br>
    -Sway Bar<br>
    -Brackets<br>
    -Lower Control Arms<br>
    -Rack &amp; Pinion<br>
    -Tie Rods<br>
    -Cross Member<br>
    <br>
    2<br>
    Clutch &amp; Flywheel<br>
    -RB Flywheel<br>
    -SPEC Clutch<br>
    -Pilot Bushing<br>
    -Clutch Alignment Tool<br>
    -Pressure Plate<br>
    -Torque to Spec<br>
    <br>
    3<br>
    Motor Prep<br>
    -Lower Harness<br>
    -Motor Mounts<br>
    -RB vs. SR Harness<br>
    <br>
    4<br>
    Transmission/Downpipe<br>
    -Throttle Bearing<br>
    -Input Shaft<br>
    -Bolt to Motor<br>
    -Starter<br>
    -Downpipe Heat Shield<br>
    -Gasket<br>
    -O2 Sensor<br>
    -12 POINT Bolts<br>
    <br>
    5<br>
    Motor/Trans Install<br>
    -Line Up Crossmember<br>
    -WOOD Block by Firewall<br>
    -Trans. Relocation Brackets<br>
    -Tap threads<br>
    -Clutch Fork Boot<br>
    <br>
    6<br>
    INSTALL lower engine bay components<br>
    -TC Rods<br>
    -Sway Bar<br>
    -Brackets<br>
    -Tie Rods<br>
    -Trans/Motor Bracket<br>
    <br>
    7<br>
    Ground Wire, Neutral Switch<br>
    Lower Harness<br>
    Upper Harness<br>
    Idle Control Valve<br>
    Coolant Temperature Sensor<br>
    2nd Sensor<br>
    2 Ground Wires<br>
    Cam Angle Sensor<br>
    Computer, Connect<br>
    <br>
    8<br>
    Q45 Throttle Body<br>
    Throttle Cable Bracket<br>
    Vacuum Booster Hose<br>
    Fuel Filter<br>
    -Return Line<br>
    -Feed Line<br>
    <br>
    9<br>
    INTERCOOLER<br>
    -Remove Bumper Support<br>
    -FABRICATE Intercooler Mounts<br>
    -Pipe/Hoses<br>
    -Cut Bumper Support<br>
    <br>
    10<br>
    -Driveshaft<br>
    -Exhaust<br>
    <br>
    11<br>
    Vacuum Lines<br>
    -PCV Valve<br>
    -Fuel Pressure Regulator<br>
    Power Steering<br>
    Pressure Line<br>
    Return Line<br>
    Connect to Pump<br>
    Reservoir<br>
    Power Steering Cooler<br>
    <br>
    12<br>
    Radiator (S14)<br>
    -Cut Fan Shroud<br>
    -Remove Plates<br>
    -Zip Tie Fan<br>
    -Remove Foam Lining<br>
    -RELOCATE a SPACER!<br>
    -Wire the Fan, Part #1<br>
    -Radiator Brackets<br>
    -Wire the Fan, Part #2<br>
    -Bleed System<br>
    <br>
    13<br>
    -Ground Wire, Block<br>
    -Slave Cylinder Install<br>
    -Slave Cylinder System Bleed<br>
    -Heater Hose Plugs<br>
    <br>
    14<br>
    -Idle Control Valve Hose<br>
    -Battery Terminal Attachment<br>
    -Braille Auto Battery<br>
    -Intercooler Piping Reinstall<br>
    -Wastegate Actuator Hose<br>
    -APEX'i Intake<br>
    -MAF Sensor<br>
    <br>
    15<br>
    -Fuse Box Bracket<br>
    -Throttle Cable S14<br>
    -Cable to Throttle Body<br>
    <br>
    16<br>
    -Fuel Pump<br>
    -Valve Covers<br>
    <br>
    17<br>
    APEX'i Power FC Intro with Steve from SR MOTOR CARS</font></b></p>
    <p><b><font color="#0000FF" size="2" face="Verdana">Parts List/Source<br>
    <br>
    R33 Skyline Front Clip - (Sr20Store.Com)<br>
    Syko Performance Rb25 Converted Upper And Lower Harness - (Sykoperformance.Com)<br>
    Syko Performance Motor Conversion Mounts - (Sykoperformance.Com)<br>
    Syko Performance Transmission Brackets - (Sykoperformance.Com)<br>
    Syko Performance Sway Bar Brackets - (Sykoperformance.Com)<br>
    Syko Performance 1 Piece Driveshaft - (Sykoperformance.Com)<br>
    Intercooler Piping - (Sykoperformance.Com)<br>
    Intercooler Core - (Meganracing.Com)<br>
    Couplers And Clamps - (Hosetechniques.Com)<br>
    Power Steering Cooler - (Sr20store.Com)<br>
    S13 91+ DOHC Power Steering Lines And Fittings - (Milano Motorsports)<br>
    Greddy RB25 Intake Manifold (Purchased From (Phase2Motortrend.Com)<br>
    Rb25 Intake Manifold Gasket - (Phase2Motortrend.Com)<br>
    Infiniti Q45 Throttle Body - (Junk Yard)<br>
    Infiniti Q45 Throttle Body Gasket - (Purchased From Infiniti Dealer)<br>
    Apex-I Power Intake - (Apexi.Com)<br>
    Apex-I Power FC &amp; Commander - (Apexi.Com)<br>
    Apex-I Auto Timer - (Apexi.Com)<br>
    Flex-A-Lite Low Profile Dual Radiator Fans (#220) - (Flex-A-Lite.Com)<br>
    Clutch Stage 3 Upgrade - (Specclutch.Com)<br>
    Flywheel - Stock Resurfaced RB25 Flywheel - (Taken To Local Shop)<br>
    Steel Braided Slave Cylinder Line - (Sr20store.Com)<br>
    Braille Auto Compact Lightweight Battery - (Brailleautodevelopment.Com)<br>
    STOCK S14 Radiator (Milano Motorsports)<br>
    High Pressure Fuel Injection Hose (Local Autoparts Store)<br>
    Z32 Fuel Filter - (Purchase From Any General Auto Parts Store)<br>
    Walbro Fuel Pump - (Phase2Motortrend.Com)<br>
    S14 Throttle Cable - (Rhddesign.Com)<br>
    Fuse Box Bracket - (Custom)<br>
    5 Quarts Of Torco Full Synthetic 5W-40 Racing Oil - (Torcoracingoils.Com)<br>
    3 Quarts Of Torco Gear Oil - (Torcoracingoils.Com)<br>
    Radiator Fluid - (Local Autoparts Store)<br>
    Power Steering Fluid - (Local Autoparts Store)</font></b></p>
