2JZ 240SX SWAP DVD (By DRIFTING.com/2JZSwap.com)
This is a sticky topic.
  • 2JZ 240SX SWAP DVD (By DRIFTING.com/2JZSwap.com)
    2JZ SWAP Teaser #1
    <object width="630" height="360"><param name="movie" value="http://www.youtube.com/v/PYokBlfspxw"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/PYokBlfspxw" type="application/x-shockwave-flash" wmode="transparent" width="630" height="360"></embed></object>
    2JZ SWAP Teaser #2
    <object width="630" height="360"><param name="movie" value="http://www.youtube.com/v/mdFv_R1FlIc"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/mdFv_R1FlIc" type="application/x-shockwave-flash" wmode="transparent" width="630" height="360"></embed></object>
    <object width="630" height="360"><param name="movie" value="http://www.youtube.com/v/fVShz5GHjIc"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/fVShz5GHjIc" type="application/x-shockwave-flash" wmode="transparent" width="630" height="360"></embed></object>
    <p><b><font size="4" face="Verdana" color="#FF0000">2JZ/1JZ SWAP PARTS LIST</font><font size="2" color="#0000FF" face="Verdana"><br>
    2JZGTE MOTOR includes shipping &amp; 6 month warrenty $2600<br>
    Transmission parts to piece together a r154 US Spec transmission from Toyota
    Supra Turbo 1989 to 1992<br>
    1JZ Bell housing $375<br>
    1JZ flywheel $275<br>
    ACT clutch kit 650 FT torque 6 puck (option for our install) $700<br>
    SHIFTER EXTENSION PLUS CORE $250 + $200<br>
    2JZ SWAP KIT PLUS CORE $1500 +$200<br>
    2JZ PLUG N PLAY WIRING $450<br>
    CLUTCH LINE SS KIT $120<br>
    FUEL LINE KIT $130<br>
    A/C KIT (option for our install) $750<br>
    THROTTLE CABLE BTACKET $45<br>
    JDM 2JZ 3inch DOWN PIPE ADAPTER $100<br>
    WATER PUMP $150<br>
    TIMING BELT $28<br>
    SERPENTINE BELT $30 UNIVERSAL SPEEDOMETER INTERFACE $79.95<br>
    UNIVERSAL TACHOMETER INTERFACE $79.99<br>
    WALBRO FUEL PUMP $100<br>
    KOYO RADIATOR WITH UPPER INLET MODDED $450<br>
    SPAL FANS $200<br>
    FAN CONTROLLER $100<br>
    2JZ 4IN INTERCOOLER KIT $650<br>
    PULLEY SET W/P,P/S,ALT $135<br>
    MISC. PARTS HEATER HOSES, RAD HOSES, CLAMPS $275</font></b></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_50.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_49.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_47.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_38.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_48.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_28.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_23.jpg" width="350" height="301"></a></p>
    <p>
    <img border="0" src="http://driftingshop.com/2JZ_SWAP_46.jpg" width="350" height="301"></a></p>
    <p><b><font face="Verdana" color="#FF0000" size="4">Chapter Outline</font><font face="Verdana" size="2" color="#0000FF"><br>
    Timing Belt<br>
    -Serpentine Belt Tensioner<br>
    -Crank Pulley<br>
    -Lower Timing Belt Cover<br>
    -Power Steering Bracket<br>
    -Top Dead Center (Check)<br>
    -Timing Belt Tensioner<br>
    -Idler<br>
    -Timing Belt<br>
    <br>
    Water Pump<br>
    -Alternator (Move)<br>
    -Water Pump Bolts<br>
    -Hard Line Bolts<br>
    -Neck Bolts<br>
    -Upper Hoses<br>
    -Reused W/P Parts <br>
    -Clutch<br>
    -Pilot Bearing<br>
    -1JZ Flywheel<br>
    -Replace Throw-out Bearing <br>
    (Not Show)<br>
    -Pressure Plate<br>
    <br>
    Transmission<br>
    -R154 Transmission<br>
    -1JZ Bell Housing<br>
    <br>
    -Shifter Kit<br>
    -2JZ Starter<br>
    -Clutch Fork<br>
    -Slave Cylinder<br>
    <br>
    Pre-wired Harness (Kit)<br>
    -Attach to Motor <br>
    <br>
    2JZ Swap Crossmember<br>
    -Steering Rack<br>
    -Motor Mounts<br>
    <br>
    -Rear Heater Hose<br>
    -Fuel Lines (Cut/Flared)<br>
    -Cutting &amp; Flaring (Not Shown)<br>
    -Install Fuel Lines (Kit)<br>
    <br>
    -Heater Hoses<br>
    -Heater Control Valve<br>
    -Power Wire Hole<br>
    <br>
    -Bolt Crossmember<br>
    -Trans. Crossmember<br>
    <br>
    -Driveshaft<br>
    -Control Arms<br>
    -Tie Rods<br>
    -Brackets<br>
    -TC Rods<br>
    -Sway Bar<br>
    -Downpipe<br>
    <br>
    -Throttle Body<br>
    -Igniter Box<br>
    -Battery Wires<br>
    -Heater Hoses (Continued)<br>
    -Clutch Line<br>
    <br>
    Fuel Lines (Continued)<br>
    -Pressure Line<br>
    -Return Line<br>
    <br>
    Power Steering<br>
    -Return Line<br>
    -Steering Linkage<br>
    -Pressure Line<br>
    -Reservoir -Radiator (Kit)<br>
    -Intercooler (Kit)<br>
    <br>
    -Dash Connector<br>
    -ECU, Attach Harness<br>
    <br>
    -Attach Shifter<br>
    -Throttle Cable<br>
    -Heater Valve Cable<br>
    -Block Vacuum Port<br>
    -Install Dipstick<br>
    <br>
    -Alternator Sub-harness<br>
    -Intake<br>
    -Fan Control Unit<br>
    <br>
    &nbsp;</font></b></p>
    2,600 engine trany or no trany
    What comes with the engine for 2,600
      talk to Carlos for details
      530-222-1555
      http://tech2motorsports.com/contact.php
        Wow
        I think that is a good way to repair your car. You should also record some videos of how to start drifting.
        I mean to say that you should also publish some lessons dvd's about learnt drifting. because there are
        many beginners who want that kind of stuff. Please tell me how I can order any DVD and also inform me
        about the payment method.
          Here's your basic drift lesson. (YouTube "basic drift lesson")
          <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/OWDRlh4ydNc"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/OWDRlh4ydNc" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
          Now go drift.
