RB25DET MOTOR BUILD (Update)
  • RB25DET MOTOR BUILD (Update)
    What up everyone,
    In about 3 weeks my life is going to be completely consumed again with another video in our RB 240 build series. I put a list together, more for myself than anything, but figured for those of you who are staying up with the project it would be interesting to know what's coming up.
    I'll be posting up continuous updates of the progress of the motor, we're shooting for a solid and reliable 500hp motor and hitting up the pro-am series in '08.
    The build DVD will likely be split into a few different DVDs allowing us to focus heavily on each sectioned covered. Stay up with us.
    Head
    - Speed O Motive
    o Head port/polish
    - TOMEI
    o Poncam Camshafts
    o Adjustable Duralumin Cam Gears
    o Strengthened Timing Belt
    o Head Gasket
    - Deatschwerks
    o 650 Injectors
    - FERREA Racing Componrents
    o Valves
    o Retainers
    o Springs
    - Phase 2 Motortrend
    o Seals
    o Nismo Thermostat
    - HKS
    o Exhaust Manifold
    - Greddy
    o Intake Manifold
    - Gizzmo
    o Phelonic Intake Gasket
    - KKR
    o KKR560 Turbo
    - NGK
    o Spark Plugs
    Block
    - Speed O Motive
    o Hone and Polish
    - JE PISTONS
    o Forged Pistons
    o Forged Pins
    o Rings
    - K1 Rods
    o Forged Connecting Rods
    - TOMEI
    o Connecting Rod Bearings
    - ACL Performance
    o Main Bearings
    - Lopez Crankshafts
    o Crank work
    o N1 Water Pump
    o Misc Seals and Gaskets
    Other Upgrades Covered
    - Driveshaft Shop
    o 450HP+ Axles
    - TORCO Racing Fluids
    o Oil
    o Assembly Lube
    o Engine Break In Fluid
    o Gear Oil
    - SPEC Clutch
    o Twin Plate Clutch
    o Aluminum Flywheel
    This is what the Ali's motor looked like after DVD #1
