240sx One Headlight not Going on...
  • 240sx One Headlight not Going on...
    My left headlight works perfectly, but the right side won't go on. Nothing wrong with the bulb. Both high beams work, but no right low beam.
    Thinking it might be the switch, but don't have spare to check. Could anyone give me some advice.
    well since it is a dual filament bubl i suggest switching bulbs from left to right... then check the wiring and fuses.
      +1.
      What model of 240? The S13's are notorious for having the wiring get loose at the headlamp unit itelf. One thing to do is while you have the lights on, wiggle the wires right at the asseble, even possibly unplug and replug them back in. It's even possible that you might have an open in the line somewhere, but check the other stuff first being as it's much easier.
