Hey, I was just wondering what kind of allignment settings you use on your car for drift/auto x/touge/etc. I want to make this thread as definitive as possible so please post your car, suspension mods, settings...and what kind of tires you're running. I'll post my settings later, just want to see if this thread gets a buzz at all.
Allignment settings (definitive thread)
I got a good write up on that, on my site...
http://www.speed-tribe.net/pages/suspension.htm
but anyway i run about 2.5deg nag camber..im farting around with diffrent toe setting this weekend..but now im at half a degree of toe out front
and no toe at all in the rear...
Im running junk tires all around i think right now there 215/40/16 but i got sevral rims to play with that are diffrent sizes..
my next suspension upgrade(after i fix a few things) is to get 25MM spacers up front and over finders...
this is all for touge/drift
I do my alignments at school. I put what I want in at factory spec, then I will add - camber to a hundreth of a degree. Make sure everything is in good condition especally the tie rods. Broke 2, second one just recently this year
Toe I keep in spec, just so Im not always wearing out my tires.. Camber doesnt wear out your tires as much as toe does.
Usually I will overcompensate when adjusting these on the alignment rack so everything will settle in the correct specs.. usually hundreths over or under depending on what I am adjusting.
Next week I will be putting my car back on the rack, because I broke my second tie rod, putting on gymkhana springs, and new shocks. I might overhaul my rack and pinion for manual steering and take out all of the power steering as well. like the pistons, plug the p.s. holes, and grease the pinion. I will get a full print out of my specs, what I have replaced and such.
crap....i just posted an alignment settings question in the Drifting section.
i guess i'm getting my answers here.
funny strongbad pic btwLast edited by miata619drifter; 03-08-2004, 05:29 PM.
First of all I have a JDM S13.
My susp mods are as follows:
Racing Gear JTC'N1 dampers
Yashio Factory Pillowball Tension Rods
Section Pillowball Rear Upper arms
Section Pillowball Toe Control Arms
Uras Urathane Subframe Spacers
Urathane Sway bar bushings
R32 GT-R rear Sway bar
And you can't really talk about susp w/o talking about chassis rigidity so:
Front/Rear Cusco Strut Tower Bars
Safety 21 9pt Roll cage
Trunk Bar
And soon to be added Pillar bar
Power also comes into play here so:
aprox: 350whp and 348ft/lbs torque
Now to the alignment settings:
Front: 2.5deg camber 0 toe 7 deg caster
rear: 2.5deg camber 0 toe (no caster adjustment in the rear)
If you are a person who doesn't have this kinda power or these susp mods you can use less rear camber, say 1deg or 1.5, and a little bit of toe out in the back, try about .5mm and work out from there. I would say no more than 1.5mm though because you are gonna go through tires so fast. Even if you don't have the rear arms get the pillow tension rods and save yourself many headaches.
yes toe can be used for adjusting the cornering..i have a little write up about alignments on my web page...
simply toe in=more stable toe out=better turn in...more toe=more tire wear..
Caster is the angle of the axis that the wheel/tire moves on while turning the stearing wheel...that very well could be the angel of the shot/strut/coilover unit..
most cars are stock toe-in to create a slight pressure between them, this gives'em steadier tracking and prevents bump steer. but when a car with a toe-in setup takes a corner the outside tires take on more than half the load. the imbalence with the inner tires creats a slight understeer into turns, (just another way manufacturers have made cars handle worse thoughout the years) and excessive toe-in will also wear your tires pretty badly. I don't tune my toe angel because I'm poor and can't afford to but if I could afford it, my tuning would definitly depend on the car I was driving. but for everone here who drives an S13 which tend to understeer but I don't need to tell you that, I would probably toe out a bit if the car wasn't my daily driver also. I would like to hear what some touge racers run because most of the touge runs are in pretty bad shape where I love and bump steer would be a big problem, it is even on the flat land here, so I would imagine that they run the stock toe angle.
