can anyone help me with turbo kits for the KA24DEs for the hatchbacks? and keep in mind that im on a budget.hehehe
Ka24de-t???
well i know f-max makes the turbo kits for the altimas and s14's...but i e-mailed them and they said they want fit the s13's....and i'm not sure what you'd have to modify to get it to fit. their kits are good and complete, but $$$. well, i consider 3500-4200 for a kit heavy but some of you rich boyz might not.
i'm sure if you're good with a welder and pipe-bender you could fab. up your own kit with junkyard turbos if you're good enough at fabricating and stuff.
nsport, Fmax, custom kit, etc
do a search on
www.freshalloy.com
www.zilvia.net
www.240sx.org
you'll find a lot of info
Exactly!if youre on a budget... then u cant have a turbo :P
try getting a manifold from sfp.com, buy a garret t3/t4 turbo, and get a greddy e-manage, custom down pipe for a garret turbo, and an intercooler. That should be well under the price of thecheapest turbo kit
how much of a budget you have to spend on this kit? $500, $1000, $3000......
a "budget" is different for different folks...
also, have you already upgraded the suspension (shocks, springs, bushings, tie-rods, end links...the whole 9 and 1/2 yards), brakes, clutch, and lsd....and is you're stock motor in good running order?
if NO to any of those questions, i say forget the turbo kit for now and fix that stuff first.
but if your suspension is tight and your brakes are safe and you've got a working LSD, engine and clutch; then i say go for more power! R-R-R.
My brother is about to do one at his shop. Not sure how he is doing it but I can ask. He makes the manifold and the intercooler. Also there is a sweet onje up the street from where I live in Knoxville Tenn. Clean instal. I have some photos. If you want them, pm me. I can get specs too if you need em.
how are turbo's for *Censored**Censored**Censored**Censored**Censored**Censored**Censored*???Originally posted by panda_3ight_6
Go N\A... Turbos are for *Censored**Censored**Censored**Censored**Censored**Censored**Censored*...ahhahaha
you DONT want more power? plus wit a turbo, you'd proly have to do alot more by yourself to keep your car running. so many problems pop up wit custom turbos
