miata/mx-5 tire setup?
  • miata/mx-5 tire setup?
    which of the following is a good size for the stock miata 14x6.5 rim to be used for drifting?
    1. 195/50/14
    2. 195/55/14
    3. 195/60/14
    4. 205/50/14
    5. 205/60/14
    44
    195.50.14
    40.91%
    18
    195.55.14
    18.18%
    8
    195.60.14
    11.36%
    5
    205.50.14
    18.18%
    8
    205.60.14
    11.36%
    5
    I know that they came with 14's, But i'd at least get a set of stock or aftermarket 15's. A slightly thinner sidewall on the tire is good because it will flex less then a tall one. With that said, imagine a 14in wheel with 50 series tire on them, it will also lower the car in a bad way because you are more likely to scrape/hit bump stops tec. Remember, you car has a 4x100 hub.... very very very common size. 205/55/15 or 205/50/15. Like i have mentioned I have 16" 's and run 205/40/16 = no sidewall flex. I am going to use a set of 14's tonight to drift with195/60/14 's and i'll let ya know how the sidewall hold up.
      'aight thanks. how are the 16" on the car, enough power to spin them?
        well, with the 16's on a 1.8 (much more power stock for stock over a 1.6), i can get 1st gear spin in the dry and 2nd in the wet.
        Well, after last night, the 14's i have on the back w 196/60/14's held up quite nicely... i was suprised how little sidewall flex there is. I'll post pics of my car later in the current set-up it on.
          yeah my 14's did 'aight last night too! i was suprised at the little amount of sidewall roll too.
