1350+ HP GTR R35 (C16 Race Fuel) Ray Hofman's Project Black Ace by SP Engineering
91 Pump – 975+ HP
C16 Race Fuel – 1350+ HP
SPE LONG BLOCK
* SPE Spec Full Blue Print and Balanced Race Short Block
* SPE Spec 4.3L Stroker Motor (94.4mm stroke)
* SPE Spec WPC Coated Block, Bearings, Rods, Pistons, Crank
* SPE Spec Sleeves
* SPE Spec Head and Main Studs
* SPE Spec Nissan Main and Rod Bearings
* SPE Spec Harmonic Damper
* SPE Spec Metal Head Gasket
* SPE Spec Stage 4 Race Head (Port/Polish)
* SPE Spec 1mm+ Valves
* SPE Spec Dual Valve Springs
* SPE Spec valve Lock
* SPE Spec Locator
* SPE Spec Titanium Retainer
* SPE Spec Ported Intake Manifold Runner
* SPE Spec 280 Degree Camshafts with 11.3/11.0 lift
SPE SPEC TWIN TURBO KIT
* SPE TD06-SH 20G Turbo x2 (SPE HYBRID) 1150HP+
* SPE Spec Stainless Tubular Manifold
* SPE Spec External Wastegate
* SPE Spec 29R XL Intercooler (294x710x115mm core)
* SPE Spec Aluminum Intercooler Pipe
* SPE Spec Blow Off Valve + Charge Pipe
* SPE Spec Cold Air Suction Pipe Kit
* SPE Spec Titek Titanium 90mm Mid Pipe
* SPE Spec Titek Titanium 90mm Exhaust
SPE FUEL SYSTEM
* SPE Spec Injectors
* SPE Spec Trip Fuel Pumps
* SPE Spec Fuel Rail
* SPE Spec Fuel Pressure Regulator and Fuel Gauge
COBB AcessPORT
* SPE Custom Tune
* 91 Octane Map
* C16 Race Gas Map
