Rotaries have 0 strokes and 4 Cycles
  • Rotaries have 0 strokes and 4 Cycles
    Give it up Xtreem....
    You cant have it both ways.
    First you bash my answer because you cant see how black and white it is.
    Then you play these little games about trick questions and semantics. Every time you are challenged, you come up with some ad-hoc (look it up) contingency for why my answer (which is perfectly correct and complete) is wrong.
    If you are trying to dispense knowledge, you have an interesting dichotomy to your methods.
    Re: Rotaries have 0 strokes and 4 Cycles
    where did I say you were wrong I said close or not the answere Im looking for. Where do you get off accusing me of anything it was my thread I will run it as I see fit. Others seemed to not have a problem with it.
      blah his trick question was easy once i thought for a moment, like you said Rotarys have no strokes, but do use the four cycle miller cycle similar to the four stage otto cycle used in normal 'four stroke' piston engines.
      right?
        right?
        SMC s in the HOUSE
          yo.. so does that mean i got it?
            And you know this
              your awnsers are always ambigious so ill reply to it.
              um thanks!
                um thanks!
                hahahaha yes you fool you know your right
                  nah i wasnt that sure, i couldnt remember if it used the miller cycle or not. at least i wasnt 100 percent sure.
                    well there is another cycle but well keep that in the chat room
                      amazing little engines arnt they (I love mine)The cycle
                      also they run so hot cause they fire on every side of the rotor everytime a new face of the rotor coems aroundignition
                        They run so hot cause they stink, I hate em, they are the worstest worst hoodigupping engines ever made on the flabberstinking earth. They smell like codfish and swiss cheese. Their mothers are a lower form of piston engine and they look like a bad bisquit that fell from a Labrador.
                        But I would never get rid of my FD and i'm puting another one in in 2 weeks so I just love to hate em.
                          neither of those links work
                            ooooooooooooook............?
