Acv???
  • Acv???
    Whats an ACV, what does it do and do you need it, cuz iv seen people remove it and wondered why.
    ACV-air control valve. This is on the lower intake manifold, and the air pump feeds air into it. The ACV controls where the air pump's air goes - into the main cat, into the exhaust manifold, or into the silencer that's under the passenger side headlight. The '89-91 NA's have their 6-ports and VDI actuated from air pump pressure, so the ACV is required unless you fab something up. Oh yeah on a S4 fc it is not needed. but if you remove it you can also take the air pump out but you'll also need a duel belt pulley for your alternator so that your water pump functions correctly.
      what would be the benefits of taking the ACV and air pump out?
        less stuff to deal with in the engine bay.
