Must Know 240SX Engine Idea's and Information
  • Must Know 240SX Engine Idea's and Information
    Can this please be a sticky??
    But here it goes.. all the info for engine swaps and wiring and codes for a 240SX...
    Turbo KA24DE [more info]
    Swap Difficulty: 1
    Aftermarket Support: 3
    Donor Car(s): S13 (1991+ US model), S14 (all US models), Hardbody (pick-up)
    Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install*
    Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install*
    Redline: 7,500rpm
    Good: cheap, fast, less work than a swap
    Bad: reliability issues in some cases when running med/high boost sustained
    Engine Cost: $800-1,500 (a few hundred more if it's rebuilt or has some parts upgraded/strengthened)
    Install Cost: n/a (everything is installed other than turbo) OR $200-500 (to install a new KA where your old KA was)
    Modified Horsepower Ceiling (stock internals): 250-350hp
    CA18DE-T [more info]
    Swap Difficulty: 4
    Aftermarket Support: 4
    Donor Car(s): Silvia (1989-1990) and 180sx (japan)
    Stock Horsepower: 173hp (175ps) @ 6400rpm
    Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm
    Redline: 8,500rpm
    Good: higher redline and cheaper than SR20DET with about the same potential, iron block
    Bad: less parts support (esp in the US), weaker head gasket than SR20DET
    Engine Cost: $2,000-3,000
    Install Cost: $1,000-2,000
    Modified Horsepower Ceiling (stock internals): 300-400hp
    SR20DE-T (S13) [more info]
    Swap Difficulty: 4
    Donor Car(s): Silvia K (japan), Kouki 180SX
    Stock HP: 203hp (205ps) @ 6000rpm
    Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm
    Redline: 7,500rpm
    Good: great output for the price with very good potential
    Bad: less output than an RB25 and weakest (stock) SR20DET, aluminum block
    Engine Cost: $2,500-3,500
    Modified Horsepower Ceiling (stock internals): 350-450hp
    SR20DE-T (S14) [more info]
    Swap Difficulty: 4
    Stock Horsepower: 217hp (220ps) @ 6000rpm
    Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm
    Redline: 7,500rpm
    Good: slightly better output than the S13 SR20DET
    Bad: VVT can be an issue when modifying heavily, aluminum block
    Engine Cost: $4,000-5,000
    Modified Horsepower Ceiling (stock internals): 350-500hp
    SR20DE-T (S15) [more info]
    Swap Difficulty: 4
    Stock Horsepower: 247hp (250ps) @ 6400rpm
    Stock Torque: 202lb/ft @ 4800rpm
    Redline: 7,500rpm
    Good: ~250hp stock, usually very low mileage, better condition than s13 or s14 engines (in most cases)
    Bad: 6 speed tranny is somewhat weak, so if you plan to increase the hp much you want to swap it for the ka tranny or an s13/14 tranny, VVT can be an issue when modifying heavily, aluminum block
    Engine Cost: $5,000-6,000
    RB20DE-T [more info]
    Swap Difficulty: 3
    Donor Car(s): Skyline R31
    Stock Horsepower: 207hp (210ps) @ 5600rpm
    Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm
    Redline: 8,000rpm
    Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block
    Bad: cost
    Engine Cost: $2,500-3,000
    Install Cost: $2,000-2,500
    Aftermarket Support: Fair
    Modified Horsepower Ceiling (stock internals): 400-450hp
    RB25DE-T [more info]
    Swap Difficulty: 3
    Donor Car(s): Skyline GT-S (R32, R33, R34)
    Stock Horsepower: 247hp (250ps) @ 6000rpm
    Stock Torque: 217lb/ft (30kgm) @ 4800rpm
    Redline: 8,000rpm
    Bad: cost, replacement parts availability
    Engine Cost: $5,000-6,500
    Install Cost: $2,500-3,000
    RB26DE-TT [more info]
    Swap Difficulty: 2
    Donor Car(s): Skyline GTR (R32,R33,R34)
    Stock Horsepower: 316hp (320ps) @ 6800rpm
    Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm
    Redline: 8,000rpm
    Good: huge potential, high horsepower stock, iron block
    Bad: AWD tranny can't be used without lots of modification and custom work. TT setup can be retained, but it's much easier to convert it to a single turbo. RB25 tranny (5 speed rather than RB26 6 speed) because of clearence and fit issues.
    Engine Cost: $7,000-8,000
    Install Cost: ~$3,000 (AWD and TT setup will be in excess of $15,000 for install)
    Modified Horsepower Ceiling (stock internals): 500-600hp
    RB30DE-T (hybrid) [more info | head conversion how-to]
    Swap Difficulty: 3
    Donor Car(s): Australian (block; RB30ET 3.0L SOHC) / Skyline GTR or GTS-T (head; RB25, RB26, or RB20)
    Stock Horsepower: ?hp (?ps) @ ???rpm
    Stock Torque: ?lb/ft (?kgm) @ ???rpm
    Redline:
    Good: good potential, iron block, cheap engine, when modified produces large hp numbers at low revs
    Bad: age, replacement parts availability, block is hard to find, RB20 head requires lots of work to fit correctly
    Engine Cost: n/a
    Install Cost: ~3,000
    Modified Horsepower Ceiling (stock internals): 350-400hp
    VG30DE-TT [more info]
    Swap Difficulty: 3
    Donor Car(s): 300ZX TT
    Stock Horsepower: 300hp (304ps) @ 6400rpm
    Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm
    Redline:
    Good: very unique and a decent engine for heavy modification
    Bad: huge cost for custom fabrication
    Engine Cost: $4,000-6,000
    Install Cost: $10,000-20,000+
    Modified Horsepower Ceiling (stock internals): 450-550hp
    VQ30DE(K) [more info]
    Swap Difficulty: 2
    Donor Car(s): VQ30DE in A32 Maxima(1995-1999 US model), VQ30DEK in A33 Maxima(2000-2001 US models)
    Stock Horsepower: 190 hp @ 5600 rpm(A32 VQ30DE), 222hp @ 6400rpm(A33 VQ30DEK)
    Stock Torque: 205 lb ft @ 4000 rpm(A32 VQ30DE), 217 lb ft @ 4000rpm(A33 VQ30DEK)
    Redline: 8,000 rpm
    Good: Can be cheap, good low-end, lightweight, very turbo friendly for an NA motor.
    Bad: Aluminum block, lack of top end on non DEK motors. Note: Can be fixed with variable intake manifold from Courtesy Nissan. Needs Pathfinder tranny.
    Engine Cost: $400+
    Install Cost: N/A
    VQ35DE [more info]
    Swap Difficulty: 2
    Aftermarket Support: 2
    Donor Car(s): 350Z, G35, kouki Maxima, kouki Altima, kouki Pathfinder
    Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima)
    Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima)
    Redline: 6,600rpm
    Bad: huge cost for custom fabrication, engine taken from a kouki Altima or Maxima will need a RWD trans
    Engine Cost: $5,000-7,500
    Modified Horsepower Ceiling (stock internals): n/a (350-400hp est.)
    http://www.zilvia.net/faqs/faqs.asp
    - Scanned Parts Catalog in GIF Format
    - Scanned Factory Service Manuals in PDF format
    - Wiring Diagrams
    http://www.srswap.com/ (Really good site , Lots of info n Picture)
    - Look in (SR Install FAQ )
    Which SR20DET to buy?
    How much does it cost?
    What parts are needed?
    Step-by-Step Install Guide
    Payment & Shipping info
    Wiring Information
    Auto Manual transmission swap
    Trouble Shooting Guide
    Old FAQ Here Parts
    Cross Reference
    MAF Wiring Charts
    Ignitor Wiring Charts
    Factory Service Manual FSM - All 240SX model (175mb file)
    http://www.neteasier.com/240sxfsm.zip
    S13 & S14 Nissan parts catalog
    http://www.ctech.ca/npclub/s13parts/
    http://www.ctech.ca/npclub/s14parts/
    Specs of 240SX (s13 and s14)
    I'am updating the link of Develish..
    S13
    http://forums.neo240sx.ca/viewforum.php?f=7
    S14
    http://forums.neo240sx.ca/viewforum.php?f=8
    sr20det ECU pinout From tru on npclub
    1 Coil pack 1 output (via power transistor Unit)
    2 Coil pack 2 output (via power transistor Unit)
    3 Tachometer signal output
    4 ECCS relay
    5 Ignition pulse monitor (for trip comp ?)
    6 Ignition Signal Ground
    7 RX data (signal from Nissan Consult hand terminal)
    8 Coil pack 3 output (via power transistor Unit)
    9 Coil pack 4 output (via power transistor Unit)
    10 -
    11 -
    12 A/T signal DT3 (autotrans gear select ?)
    13 Ignition Signal Ground
    14 CLK clock (timing signal) ?
    15 TX data (signal to Nissan Consult hand terminal)
    16 AFM Signal input (air flow meter)
    17 AFM ground
    18 Water temp sensor input
    19 Oxygen Sensor input (O2)
    20 TPS input (throttle position sensor)
    21 Sensor ground
    22 CAS 180deg signal (crank angle sensor)
    23 CHK check (check start) ?
    24 Monitor check lamp (Red) (fault code lamp output)
    25 Exhaust over temp warning lamp output
    26 Exhaust temp sensor input (behind the Cat)
    27 Detonation sensor input (knock sensor)
    28 TPS for A/T (kick down switch)
    29 Sensor ground
    30 CAS 180deg signal (crank angle sensor)
    31 CAS 1deg signal (crank angle sensor)
    32 Speed sensor input
    33 -
    34 START signal (from ignition switch)
    35 A/T neutral switch input
    36 IGN (ignition ON, from ignition switch)
    37 TPS power output (power to throttle position sensor)
    38 ECCS power
    39 ECCS ground
    40 CAS 1deg signal (crank angle sensor)
    41 A/C on input (Air Con ON from A/C panel or climate control)
    42 A/T signal DT1 (auto trans gear select ?)
    43 Power steering switch (speed proportional control output)
    44 A/T signal DT1 (auto trans gear select ?)
    45 Ambient air temp sensor input
    46 ECCS backup power
    47 ECCS power
    48 ECCS ground
    101 Injector No 1 drive output
    102 EAI control solenoid output (EGR valve control ?)
    103 Injector No 3 drive output
    104 Fuel pump relay output
    105 Fuel pressure control module
    106 A/C on output (Air Conditioner on relay signal)
    107 Injector ground
    108 Injector ground
    109 Reverse electrical flow return circuit (alternator fail input ?)
    110 Injector No 2 drive output
    111 Turbo boost pressure control solenoid (over boost cut ?)
    112 Injector No 4 drive output
    113 AAC valve control (Auxiliary Air Control, idle speed control)
    114 -
    115 -
    116 Injector ground
    ca18det ECU pinout From tru on npclub
    ECU PINS - Description of use
    1 - Coil pack 1 output (via power transistor Unit)
    2 - Coil pack 2 output (via power transistor Unit)
    3 - Coil pack 3 output (via power transistor Unit)
    5 - Boost pressure control solenoid (domestic Japanese cars only, not Euro models)
    6 - Air conditioner relay
    7 - Tacho drive output to tachometer
    8 - Variable intake butterfly control solenoid (domestic Japanese cars only, not Euro models)
    10 - Ground
    11 - Coil pack 4 output (via power transistor Unit)
    16 - ECCS system relay (earth = on)
    17 - Injector pulse duty output (to trip computer for fuel usage measurement)
    18 - Fuel pump relay (earth = on)
    20 - Ground
    23 - Knock sensor input
    26 - Air flow meter pin B (ground ?)
    27 - Air flow meter pin A
    28 - Coolant temp sensor input
    29 - Oxygen sensor input (unleaded catalyzer model only)
    30 - Sensor earth
    32 - Check lamp output to check connector (green)
    33 - Check lamp output to check connector (red)
    37 - Air flow meter pin D (non cat models ? )
    38 - Throttle Position Sensor potentiometer (wiper)
    41 - Crank angle sensor 180 deg input
    42 - Crank angle sensor 1 deg input
    43 - start signal (cranking) from ignition switch
    44 - Neutral(manual) / park(auto) gearbox switch signal
    45 - Ignition On switch signal
    46 - Air conditioner thermostat input (ECU controls AC activation)
    47 - To check connector ?????
    48 - TPS potentiometer battery output (5 volt?)
    49 - Battery from ECCS relay
    50 - Ground
    51 - Crank angle sensor 180 deg input
    52 - Crank angle sensor 1 deg input
    53 - Speed sensor input via the speedometer
    54 - TPS switch (throttle idle position)
    55 - Ambient air temp sensor input (sensor is in front of radiator)
    56 - ?????
    57 - TPS switch (full throttle position)Auto trans? (kick down switch)
    58 - battery, unswitched
    59 - battery from ECCS relay
    60 - Ground
    101 - Injector No 1 drive output
    103 - Injector No 3 drive output
    106 - AAC (aux/idle air control) valve output
    107 - Injector drive ground
    108 - Injector drive ground
    109 - Battery from ECCS relay
    110 - Injector No 2 drive output
    111 - ? CA18DET A/T ? or pressure reg control valve?
    112 - Injector No 4 drive output
    115 - Heater output for O2 sensor (unleaded catalyzer model only)
    116 - Injector drive ground
    240sx brake upgrade SPECS
    http://www.npclub.com/bb/showthread...=&threadid=8001
    Reading the fault codes on your CA18DET ECU
    http://www.npclub.com/bb/showthread...=&threadid=8074
    300ZX (Z32) brake conversion for 240SX
    http://www.npclub.com/bb/showthread...=&threadid=6665
    S13 Silvia Front End Conversion info
    http://sr20.hybrids.jp/installations/silvia_front/
    ECU Wiring Diagram for 240SX 91-92-93
    http://www.ctech.ca/npclub/npclub/r...ecu-diagram.jpg
    How-To do a Self test KA24DE ECU diagnostic (french)
    http://www.npclub.com/bb/showthread...=&threadid=4548
      Some little info on the KA...
      http://www.unstable-hybrids.com/FAQ_KA.htm
      KA24DE Turbo
      http://www.back-yard-productions.com/CONROY.htm
      Nissan Engine Info...
      http://sr20det.nismo.org/nissanengines.htm
      More KA24DE Turbos...
      http://www.socal240sx.org/articles/superstreet0801.html
      SR20 FAQ's
      http://srswap.com/faq2.htm
      http://srswap.com/faq.htm
      Auto-Manual Tranny swap (especially the wiring).
      Plus other excellent info on KA24DE/KA24DET, brake swap, VLSD swap, hacked MAF.......etc
      http://www.ka24development.com/index.html
        Thats some GREAT info but im just wondering how is it easier to swap in a RB26dett than to swap an sr20 ?
          yea also on your scale its easier to drop in the vq35de in the 240??? you might need to change your difficulty ratings. But damn good info reguardless.
            ALright, I have a 1993 240sx, with an s13 sr20det. How hard would it be to put an S14 sr20 in it? Im thinking of buying the whole front clips, so that may help... thanks
            Metalmulisha
              great info
                none of the links work.
                  well they were posted two years ago.
