ok, so i was looking through the old posts about hicas, and i read that u cant replace the steering wheel on a hicas 240sx. is this true? theres NO way to replace the wheel?
hicas steering wheel
http://www.drifting.com/forums/showt...s&pagenumber=2
ae86shinchu said u cant change the hub because of the sensors. i know u can stop hicas by using one of those eliminators.
yes, dump the hicas thing up front when you're swapping. If you have a look at how your steering wheel is mounted, you'll see that there's a spline and a nut on it. A couple wires and what not. That's the common thing for most cars and I seriously doubt that the hicas models are any different. The sensors can be removed, and other things can be done to make it fit. Chance of nissan forking over the $$$ to make a totally new steering unit are pretty slim, so I'd still put my money on able to change the steering wheel after you pull the sensors off if there are some behind the steering wheel. Make sure you pull the harnesses and what not for the hicas unit in the engine bay as your ecu might throw a code.
check out a 91+ fsm and that should give you the differences, the steering shaft has sensors on it for hicas, the ps pump, the lines for the ps, lines that run to the rear, and then slap on a eliminator bar on your rear. It's a bit of work to get a hicas to non hicas form. consider getting a non-hicas model seriously but try to get the guy to sell the diff from the hicas model since that's got the vlsd in it. lol
