RX7 stuff.
  • #31
    There are alot of online explinations of rotarys. Just google "rotary diagram" "rotary explination" etc....
    • #32
      yeah google is good for everything.
      • #33
        Originally posted by su_maverick
        oh geez...I was kidding. I guess this time they are going to take a stock RX-8 and have it beat a R34. sigh.....
        hahaha I know u were kidding....
        • #34
          http://auto.howstuffworks.com/rotary-engine1.htm
          All you need to know.
          • #35
            yeah i already used how it works or whatever. i am just going to learn about any big problems and how they can be repaired.
            • #36
              i actually read the information in a super street that talked about replacing the apex seals or something. are the stock ones a big problem?
              • #37
                no not really it's just a fact of life that the rotary engines need to be rebuilt earlier than most piston motors
                • #38
                  I know this is a horrible comparison but for those of you used to piston engines. Think of the apex seals as a head gasket, for compresion reasons. The ones that come stock are adequate (spelling) but if you are going to rebuild a motor I recommend the 3mm seals, you can get them from alot of rotary shops out there.
                  • #39
                    exactly
                    • #40
                      i really havent had to many problems wiht my fd yet, knock on wood, ive got quite a few mods, and onece i got my knock sensor, my worriedness(is that even a word) decreased a little, im not saying i go out and raise the boost to 19 for daily driving lol but ya, fds are great i luv mine, but i dnt think many pple should get them, cuz u have to be straight up dedicated
                      • #41
                        • #42
                          I have heard alot of people say that a safe boost is around 13. The best way to monitor your engine is to get an air/fuel gauge. It is a good warning if your engine is running lean, which is BAD.
                          • #43
                            in regards to the 3mm apex seals the reason people use them is they are stronger than 2mm seals therefore more resistant to detonation.
                            but the 2mm apex seals seal better than the 3mm so its a compromise
                            my engine builder is using rx8 style 2mm seals in my motor, they are ment to be stronger than your normal 2mm seal but seal better than the 3mm
                            the best apex seals in the world are hurley 2mm seals, they have been designed for race engines and and very strong and also seal very well
                            • #44
                              also most a/f gauges are not very good as they are not accurate, and respond to slowly, by the time you notice something on one of them damage is prob already done.
                              a good option (if you feel you need it) is to get a aftermarket computer with wide band a/f option (wide band a/f is similar to what they use at dynos to keep an eye on your a/f's, this is the best option you can get with out getting professional equipment) most of the top ecu's like microtech, haltech and motec have the wide band option
                              cheers
                              • #45
                                thanks for the info, I am even learning alot
