Clutch problem
  • Clutch problem
    I got a problem with my clutch pedal on my 240. Its stuck to the floor. When I pull it up it stays up, but when I push it down, its stuck. Its like there is no pressure against the clutch pedal. When its stuck and I try to start the car (with the clutch pedal to the floor) the car moved by its self forward when its in first. If I am holding the brakes, it tries to go forward. I dont know what the problem is. Any ideas?
    Did you check your clutch fluid?
      No I did not. Can you give me an idea where I can find that? Heh
      Anything else?
        Anything else?
          i had that problem with my fc, the clutch fluid had leaked out. just put some dot 3 or 4 into it and just pump the clutch till its back to normal. you should get it checked out also cause you might have a bad leak.
            Anything else?
            Right next to your blinker fluid, behind the muffler bearings
              LMAO! thats not where its at, its right next to the left blinker air sensor behind the quantom difribulator. DUH
                Im an idiot. I still dont know where it is. Is it the thing with the red arrow... thats the only thing without fluid, but I didnt want to pour fluid where it shouldnt go.
                  Yep, and it looks empty
                    Filled that up and pumped the clutch... even pulled the clutch pedal up and down... and nothing.
                    Any other ideas?
                      you have to pump it
                      pour some in and pump teh clutch a bit then pour more and keep it going and it should be stiff again
                        Did that. I get no results. Isnt there anything else it could be?
                          Does the resevoir stay full?
                            Yes, reservoir stays full.
                              does everyone have a problem with the radiator overflow tank cracking and turning yellow? almost EVERYONE i know has this problem, looks like you have it too..
