Originally posted by 180fan
Next, if you remove the PCV from the system, you don't get oscillations in your rpm from 1k to 2k. All the PCV does is vent the extra pressure from the crankcase back to the intake. Check that, it's a one way valve and will not cause oscillations like you're describing unless you've got a vac leak. Check the FSM if you don't believe me.
slammed on his brakes infront of me and so i locked up my brakes and rearended him so if anyone knows a good s13 or s14 shell for cheap so i can get my sr20det back on the road please help
