S13 crankshaft vs. S14 crankshaft
  • S13 crankshaft vs. S14 crankshaft
    are these the same. I found one out of a S13 redtop and I need to put it in my S14 engine. Will this work? Just want to make sure. THanks for the input guys!!!
    Yes it will work...but you have to match the stamp numbers and get the right bearings, good luck. My engine uses an NA S14 crank. Makes 400hp.
    Ernie Fixmer
    Formula Drift/VR Motoring/Robinson Helicopter
    Lakewood, CA 90712
      thanks alot Ernie. where is a good place to get bearings?
        where do you live?...if you are in SoCal area, then go to Superior/Puente Hills Nissan and talk to Mikey. He can get anything having to do with SR20s or RBs or whatever. Like I said before you will want to consult your FSM(factory service manual) before you order to determine which bearings you will need and check your stamps on the block and the crank.
        Ernie Fixmer
        Lakewood, CA 90712
          Actually any Nissan dealer should be able to get the bearings. You need the numbers though.
          Ernie Fixmer
          Lakewood, CA 90712
