Driveshaft
  • Driveshaft
    Will I need a special Silvia driveshaft if im swapping in a SR20DET and doing a manual conversion? (in an 90)
    As far as I know, the SR20DET's transmission and the KA24's transmission are exactly the same from the end of the bellhousing, back. (Except for gearing) That means all you need is any manual driveshaft and you're good to go.
      alright...would i be able to just get the fornt half of the driveshaft? or do i need the whoooole manual driveshaft?
        the front half is different for AT and MT's. Otherwise it should fit no problem between KA and SR IF you cut the SR tranny end cover thing or switch it to the KA one.
