Question Abt 5zigen Fn01r-c
  • Question Abt 5zigen Fn01r-c
    Fn01r-c (flat Black)
    PCD: 4x114.3
    ET: 35
    Front
    PCD: 4x114.3
    ET: 35
    Rear
    My Questions are
    1) Will tein He or Spl's Coil-Over fit??
    2) I wanna get 215/45-17 for the front
    235/45-17 for the rear
    is this setup ok??
    thanks for the helps
    I run stock SE wheels with 10mm spacers to fit without rubbing. The overall offset is +25.
    Front: search Zilvia.net
    Rear: should clear, again search Zilvia
    Lots of people run FN01R-Cs and you should be able to figure it out pretty easily.
      stock se wheels with a 10mm spacer are not +25 offset. thoes sizes totally suck and will be competly sunken and crappy. why do you want to stagger your tires, that will make you understeer. get 17x9 +15 front and 17x10 +12 rear and run 225/45 all around.
