Bushings are usually located where all your suspension bits connect to the chassis. They are there to dampen vibration and reduce shock. In road cars they usually consist of rubber "tubes" with a steel insert that a bolt will pass through. I don't know how to really describe them, just look where your suspension components meet your chassis and you'll see the rubber. The problem with the factory bushings is that they are soft and compliant, this provieds a better and quieter ride. They are detrimental to handling because they flex under load, causing the suspension geometry to change while cornering. This change can lead to unpredicatble and sloppy handling. When upgrading you would go to a polyurethane bushing. A full kit will cost around 120.00 or so depending on what car you have. They are an absolute nightmare to put in, but well worth the effort. The ride is much harsher however the handling gain is fantastic. Look to company's such as Prothane or Energy Suspension for bushing kits.
Bushings
You can describe bushings using your joints on your bones as an analogy. The cartiliedge between your bones acts as a buffer.
When you have soft bushings, you're going to have a soft ride but not be able to take a hard beating without severe damage... I've worn out the factory bushings on all the cars I have owned thus far.
With polyurethane bushings, they're stiff enough to take a beating, but yet still dampen the ride considerablely.
I honestly don't recommend the aluminum bushings if this is going to be a street application as you're going to damage your suspension parts and frame in the long run due to undamped vibrations (Resonance)...
(Someone hurry up and hire me... Please.. I need a job working on this stuff. I'll relocate to anywhere...I studdied Mechanical Enginering...)
Matt
Originally posted by BlueDragon871
ill higher youyou can be my fd mechanic i could pay you umm, stuff and possibly even money eventually, but ya u had it right on the money, great analogy
I can build parts for racing...
Matt.
hehehe... I meant the factory...
Let's put it this way, I'm not a greese monkey. I know $*$^ about actually fixing a car. I didn't get a chance to do the wrench time. I do more now as of late and I enjoy it, but I'm an engineer. I'd be designing the parts.
Matt.
Originally posted by Ralli///Art GS
Ooops, that was in response to someones post, but ended up being a new thread....
Originally posted by AlexPfeiffer
Who the hell is stupid enough to use aluminum, that is just wrong. If you use anything other than a rubber or a bearing (rod end or heim joint), then it would be Delrin.
Matt.
ive ridden in cars with poly bushings, couldnt feel it at all. heim joints are an improvment though. stiffens things up nice.
about who would be stupid enough to use aluminum bushings, *shrug* ive seen them for sale, never ran them myself. bushings are just too much work for somthing that you would have to replace later when you run out of adjustment. (imho)
